Zum Hauptinhalt wechseln
LG WM3050CW Pump Hose Replacement
Was du brauchst
  1. LG WM3050CW Pump Hose Replacement, Safety Precautions: Schritt 1, Bild 1 von 2 LG WM3050CW Pump Hose Replacement, Safety Precautions: Schritt 1, Bild 2 von 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Pump Hose Replacement, Unfasten the top panel: Schritt 2, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Unfasten the top panel: Schritt 2, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Unfasten the top panel: Schritt 2, Bild 3 von 3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Pump Hose Replacement, Remove the top panel: Schritt 3, Bild 1 von 2 LG WM3050CW Pump Hose Replacement, Remove the top panel: Schritt 3, Bild 2 von 2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Pump Hose Replacement: Schritt 4, Bild 1 von 2 LG WM3050CW Pump Hose Replacement: Schritt 4, Bild 2 von 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Pump Hose Replacement, Remove the detergent drawer: Schritt 5, Bild 1 von 2 LG WM3050CW Pump Hose Replacement, Remove the detergent drawer: Schritt 5, Bild 2 von 2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG WM3050CW Pump Hose Replacement: Schritt 6, Bild 1 von 3 LG WM3050CW Pump Hose Replacement: Schritt 6, Bild 2 von 3 LG WM3050CW Pump Hose Replacement: Schritt 6, Bild 3 von 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG WM3050CW Pump Hose Replacement, Disconnect the control panel: Schritt 7, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Disconnect the control panel: Schritt 7, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Disconnect the control panel: Schritt 7, Bild 3 von 3
    • Disconnect the three harness connectors for the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG WM3050CW Pump Hose Replacement, Unfasten the control panel: Schritt 8, Bild 1 von 2 LG WM3050CW Pump Hose Replacement, Unfasten the control panel: Schritt 8, Bild 2 von 2
    • Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
  9. LG WM3050CW Pump Hose Replacement, Unfasten the detergent dispenser: Schritt 9, Bild 1 von 1
    • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
  10. LG WM3050CW Pump Hose Replacement, Unclip the control panel: Schritt 10, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Unclip the control panel: Schritt 10, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Unclip the control panel: Schritt 10, Bild 3 von 3
    • Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
    • Twist the screwdriver to release the clips securing the control panel.
    • Repeat this procedure for the remaining clips along the control panel.
  11. LG WM3050CW Pump Hose Replacement, Remove the control panel: Schritt 11, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Remove the control panel: Schritt 11, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Remove the control panel: Schritt 11, Bild 3 von 3
    • Lift the control panel upward to completely separate it from the chassis.
    • Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
    • Remove the control panel.
  12. LG WM3050CW Pump Hose Replacement, Open the door: Schritt 12, Bild 1 von 2 LG WM3050CW Pump Hose Replacement, Open the door: Schritt 12, Bild 2 von 2
    • Open the front door completely.
  13. LG WM3050CW Pump Hose Replacement, Remove the boot ring: Schritt 13, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Remove the boot ring: Schritt 13, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Remove the boot ring: Schritt 13, Bild 3 von 3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG WM3050CW Pump Hose Replacement: Schritt 14, Bild 1 von 3 LG WM3050CW Pump Hose Replacement: Schritt 14, Bild 2 von 3 LG WM3050CW Pump Hose Replacement: Schritt 14, Bild 3 von 3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • This procedure will take significant force.
  15. LG WM3050CW Pump Hose Replacement, Disconnect the boot: Schritt 15, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Disconnect the boot: Schritt 15, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Disconnect the boot: Schritt 15, Bild 3 von 3
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG WM3050CW Pump Hose Replacement: Schritt 16, Bild 1 von 3 LG WM3050CW Pump Hose Replacement: Schritt 16, Bild 2 von 3 LG WM3050CW Pump Hose Replacement: Schritt 16, Bild 3 von 3
    • Work your fingers around the boot until its completely separated from the panel.
  17. LG WM3050CW Pump Hose Replacement, Remove the filter panel: Schritt 17, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Remove the filter panel: Schritt 17, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Remove the filter panel: Schritt 17, Bild 3 von 3
    • Open the filter panel at the bottom left of the front panel.
    • Twist the filter panel upward to unclip it from the front panel.
  18. LG WM3050CW Pump Hose Replacement, Unfasten the filter trim: Schritt 18, Bild 1 von 1
    • Use a Phillips driver to remove the two 12.8 mm‑long screws securing the filter trim.
  19. LG WM3050CW Pump Hose Replacement, Remove the filter trim: Schritt 19, Bild 1 von 2 LG WM3050CW Pump Hose Replacement, Remove the filter trim: Schritt 19, Bild 2 von 2
    • Pull the filter trim straight off the front panel to remove it.
  20. LG WM3050CW Pump Hose Replacement, Unfasten the lower front panel: Schritt 20, Bild 1 von 1
    • Use a Phillips driver to remove the 12.8 mm-long screw securing the lower front panel.
  21. LG WM3050CW Pump Hose Replacement, Unfasten the door latch: Schritt 21, Bild 1 von 1
    • Use a Phillips driver to remove the two 16 mm‑long screws securing the door latch.
  22. LG WM3050CW Pump Hose Replacement, Remove the door latch: Schritt 22, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Remove the door latch: Schritt 22, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Remove the door latch: Schritt 22, Bild 3 von 3
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  23. LG WM3050CW Pump Hose Replacement, Unfasten the front panel: Schritt 23, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Unfasten the front panel: Schritt 23, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Unfasten the front panel: Schritt 23, Bild 3 von 3
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Use a Phillips driver, or a 7 mm nut driver, to remove the six 15 mm‑long screws securing the front panel.
  24. LG WM3050CW Pump Hose Replacement, Remove the front panel: Schritt 24, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Remove the front panel: Schritt 24, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Remove the front panel: Schritt 24, Bild 3 von 3
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  25. LG WM3050CW Pump Hose Replacement: Schritt 25, Bild 1 von 1
    • Remove the front panel.
  26. LG WM3050CW Pump Hose Replacement, Disconnect the tub to pump hose: Schritt 26, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Disconnect the tub to pump hose: Schritt 26, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Disconnect the tub to pump hose: Schritt 26, Bild 3 von 3
    • Use slip joint pliers to pinch the tub to pump hose clamp and pull it away from the assembly.
    • Pull the hose straight off the assembly to disconnect it.
  27. LG WM3050CW Pump Hose Replacement, Unfasten the rear panel: Schritt 27, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Unfasten the rear panel: Schritt 27, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Unfasten the rear panel: Schritt 27, Bild 3 von 3
    • Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
  28. LG WM3050CW Pump Hose Replacement, Remove the rear panel: Schritt 28, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Remove the rear panel: Schritt 28, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Remove the rear panel: Schritt 28, Bild 3 von 3
    • Lift the rear panel upward to release its bottom clips.
    • Pull the rear panel away from the chassis to release the remaining clips.
  29. LG WM3050CW Pump Hose Replacement: Schritt 29, Bild 1 von 1
    • Remove the rear panel.
  30. LG WM3050CW Pump Hose Replacement, Disconnect the air dome: Schritt 30, Bild 1 von 2 LG WM3050CW Pump Hose Replacement, Disconnect the air dome: Schritt 30, Bild 2 von 2
    • Pull the air dome hose straight up to disconnect it.
  31. LG WM3050CW Pump Hose Replacement, Unfasten the air dome: Schritt 31, Bild 1 von 1
    • Use a Phillips driver to remove the two 16.5 mm‑long screws securing the air dome.
  32. LG WM3050CW Pump Hose Replacement: Schritt 32, Bild 1 von 3 LG WM3050CW Pump Hose Replacement: Schritt 32, Bild 2 von 3 LG WM3050CW Pump Hose Replacement: Schritt 32, Bild 3 von 3
    • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
  33. LG WM3050CW Pump Hose Replacement, Remove the air dome: Schritt 33, Bild 1 von 3 LG WM3050CW Pump Hose Replacement, Remove the air dome: Schritt 33, Bild 2 von 3 LG WM3050CW Pump Hose Replacement, Remove the air dome: Schritt 33, Bild 3 von 3
    • Pull the air dome straight off its hose to remove it.
    • During reassembly, make sure the air dome nub is aligned properly with its slot in the hose.
  34. LG WM3050CW Pump Hose Replacement, Loosen the pump hose: Schritt 34, Bild 1 von 2 LG WM3050CW Pump Hose Replacement, Loosen the pump hose: Schritt 34, Bild 2 von 2
    • Use a Phillips driver to loosen the pump hose from the drum enough to disconnect it.
  35. LG WM3050CW Pump Hose Replacement, Disconnect the pump hose: Schritt 35, Bild 1 von 2 LG WM3050CW Pump Hose Replacement, Disconnect the pump hose: Schritt 35, Bild 2 von 2
    • Pull the pump hose straight off the drum to disconnect it.
  36. LG WM3050CW Pump Hose Replacement, Remove the pump hose: Schritt 36, Bild 1 von 1
    • Remove the pump hose.
    • During reassembly, use liquid laundry detergent to lubricate the hose around its tub connection.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
38.497 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.608 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 285
