Zum Hauptinhalt wechseln
LG WM3050CW Rotor Position Sensor Replacement
Was du brauchst
  1. LG WM3050CW Rotor Position Sensor Replacement, Safety Precautions: Schritt 1, Bild 1 von 2 LG WM3050CW Rotor Position Sensor Replacement, Safety Precautions: Schritt 1, Bild 2 von 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Rotor Position Sensor Replacement, Unfasten the rear panel: Schritt 2, Bild 1 von 3 LG WM3050CW Rotor Position Sensor Replacement, Unfasten the rear panel: Schritt 2, Bild 2 von 3 LG WM3050CW Rotor Position Sensor Replacement, Unfasten the rear panel: Schritt 2, Bild 3 von 3
    • Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
  3. LG WM3050CW Rotor Position Sensor Replacement, Remove the rear panel: Schritt 3, Bild 1 von 3 LG WM3050CW Rotor Position Sensor Replacement, Remove the rear panel: Schritt 3, Bild 2 von 3 LG WM3050CW Rotor Position Sensor Replacement, Remove the rear panel: Schritt 3, Bild 3 von 3
    • Lift the rear panel upward to release its bottom clips.
    • Pull the rear panel away from the chassis to release the remaining clips.
  4. LG WM3050CW Rotor Position Sensor Replacement: Schritt 4, Bild 1 von 1
    • Remove the rear panel.
  5. LG WM3050CW Rotor Position Sensor Replacement, Unfasten the rotor: Schritt 5, Bild 1 von 2 LG WM3050CW Rotor Position Sensor Replacement, Unfasten the rotor: Schritt 5, Bild 2 von 2
    • Use an impact driver to remove the 17 mm nut securing the rotor.
    • Alternatively, you can use a wrench and a hammer to loosen the nut.
    • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
  6. LG WM3050CW Rotor Position Sensor Replacement, Remove the rotor: Schritt 6, Bild 1 von 2 LG WM3050CW Rotor Position Sensor Replacement, Remove the rotor: Schritt 6, Bild 2 von 2
    • The rotor is magnetically attracted to the stator.
    • Pull the rotor straight off the stator and drive shaft splines to remove it.
    • Wiggle the rotor as you pull to help disconnect it.
    • This may require significant force.
    • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
  7. LG WM3050CW Rotor Position Sensor Replacement, Unfasten the motor harness clamps: Schritt 7, Bild 1 von 1
    • Use a Phillips driver to remove the three 16.6 mm‑long screws securing the motor harness clamps.
  8. LG WM3050CW Rotor Position Sensor Replacement, Unfasten the stator: Schritt 8, Bild 1 von 2 LG WM3050CW Rotor Position Sensor Replacement, Unfasten the stator: Schritt 8, Bild 2 von 2
    • Hold the stator up as you unfasten the last few bolts, as it can fall over unexpectedly.
    • Use a 10 mm socket wrench to remove the six 68 mm-long bolts securing the stator.
    • During reassembly, refasten the screws in a "star" pattern.
  9. LG WM3050CW Rotor Position Sensor Replacement, Reposition the stator: Schritt 9, Bild 1 von 3 LG WM3050CW Rotor Position Sensor Replacement, Reposition the stator: Schritt 9, Bild 2 von 3 LG WM3050CW Rotor Position Sensor Replacement, Reposition the stator: Schritt 9, Bild 3 von 3
    • Don't pull the stator too far away from the device, as it's still connected by wires.
    • Pull the stator off of the drum and flip it so its rear is facing upward.
    • Note the position of the stator before continuing, as you will need it face the proper direction during reassembly.
  10. LG WM3050CW Rotor Position Sensor Replacement, Disconnect the rotor position sensor: Schritt 10, Bild 1 von 2 LG WM3050CW Rotor Position Sensor Replacement, Disconnect the rotor position sensor: Schritt 10, Bild 2 von 2
    • Pull the rotor position sensor harness connector straight out of its socket to disconnect it.
  11. LG WM3050CW Rotor Position Sensor Replacement, Remove the rotor position sensor: Schritt 11, Bild 1 von 3 LG WM3050CW Rotor Position Sensor Replacement, Remove the rotor position sensor: Schritt 11, Bild 2 von 3 LG WM3050CW Rotor Position Sensor Replacement, Remove the rotor position sensor: Schritt 11, Bild 3 von 3
    • Use your fingers to unclip the rotor position sensor from the stator.
    • Pull the sensor away from the stator to completely unclip it.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
Bill Gilbert
38.497 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.623 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 774
