Zum Hauptinhalt wechseln
Laser Lens Cleaning
Was du brauchst
  1. Laser Lens Cleaning, Top Panel: Schritt 1, Bild 1 von 2 Laser Lens Cleaning, Top Panel: Schritt 1, Bild 2 von 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
    Frag FixBot
    Kommentar hinzufügen
  2. Laser Lens Cleaning: Schritt 2, Bild 1 von 2 Laser Lens Cleaning: Schritt 2, Bild 2 von 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
    Frag FixBot
  3. Laser Lens Cleaning, Laser Lens Cleaning: Schritt 3, Bild 1 von 2 Laser Lens Cleaning, Laser Lens Cleaning: Schritt 3, Bild 2 von 2
    • Locate the lens on the disc drive.
    • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
    • Dip one end of a cotton swab in rubbing alcohol.
    • Lightly dab the swab on the lens. Be very gentle.
    • Let the lens dry before replacing the top plate of the DVD player.
    Frag FixBot
Abschluss
16 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 21-20, Maness Fall 2011 Mitglied von Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Mitglieder
9 Anleitungen geschrieben
5 Kommentare zur Anleitung
This item was not appropriate, thank you for trying.
bigd734 - Antwort Teilen
Works on Samsung's box(home theater), thank you!
CarlBraun - Antwort Teilen
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - Antwort Teilen
ne fonctionne toujours pas
JEAN PIERRE LARVOR - Antwort Teilen
My problem I think is alignment
James Smith - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 28
Letzte 7 Tage: 149
Letzte 30 Tage: 692
Insgesamt: 61,988
