Einleitung
It is critical that an ACLI power plug is fully functional and free of error. A damaged ACLI plug won’t provide power to your space heater.
Please refer to this Troubleshooting guide before beginning to make sure replacing the ACLI plug is the correct action to fix your device.
For this Lasko CD08200 replacement guide, you will need:
- Torx Security 15 (TR15 bit)
- Phillips 2 (PH2 bit)
- Solder Iron
- Metal Spudger
Not sure how to solder? Follow this soldering guide before starting.
Was du brauchst
Turn over the device and place it on its head. Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
Remove the power cord casing from the device case.
Trace the two grey cables of the ACLI plug to their white wire connectors. Pinch the wire connector and pull out the wire connector with pliers.
Heat up the end of the wire from the tip of the solder iron.
While the wire is still hot, untwist the wires using pliers.
Gently free the wire from the power cord casing with a spudger.
Pull the ACLI cable out from the power cord casing with your hands.
Pull the entire ACLI cable out of the device.
