Einleitung
This guide will show you how to replace the speaker on your LeapFrog LeapPad 32400.
In this guide you will be removing internal components to replace or repair the speaker component for this device.
Check the troubleshooting page for symptoms to make sure this guide is the best route: LeapFrog LeapPad #32400 Troubleshooting Page
Was du brauchst
Turn the tablet so the back is facing up.
Remove the battery covers by sliding the covers towards the sides and away from the center of the device.
Take out the AA batteries from both battery compartments of the device.
Replace batteries as needed.
Remove three 7 mm screws using a Phillips #1 screwdriver.
Remove the single 6 mm screw using a Phillips #1 screwdriver.
Remove the single 10 mm screw using a Phillips #1 screwdriver.
Use a small plastic opening tool to separate the colored front cover from the white rear cover of the device.
With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and pull the pieces apart.
Once only the top edge remains connected, pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces front and rear cover together.
Separate the motherboard from the back side of the device by detaching the black and red wire connection from the back cover.
Remove the single 10 mm screw from the device using a Phillips #1 screwdriver.
Remove the single 7 mm screw from the device using a Phillips #1 screwdriver.
Gently lift the motherboard away from the back cover.
Peel back the tape on the display ribbon cable connector.
Gently pull on the display ribbon cable and it should easily slide out of the connecter.
Desolder the speaker wire connections at one of the two terminal locations shown.
