Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 5-1570 USB Port Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 3, Bild 2 von 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Fan: Schritt 4, Bild 1 von 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  5. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 5, Bild 1 von 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  6. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 6, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  7. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: Schritt 7, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: Schritt 7, Bild 2 von 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  8. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 8, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 8, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 8, Bild 3 von 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  9. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: Schritt 9, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: Schritt 9, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: Schritt 9, Bild 3 von 3
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  10. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 10, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 10, Bild 2 von 2
    • Using your hands, gently pull the left speaker up and out of the device.
  11. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 11, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 11, Bild 2 von 2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
  12. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
  13. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 13, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 13, Bild 2 von 2
    • Disconnect the auxiliary port cable from the motherboard.
  14. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 14, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 14, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 14, Bild 3 von 3
    • Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
    • Lift up the connector locking tab and disconnect the cables from the motherboard.
  15. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 15, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 15, Bild 2 von 2
    • Disconnect the display cable from the motherboard.
  16. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 16, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 16, Bild 2 von 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  17. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 17, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: Schritt 17, Bild 2 von 2
    • Carefully lift and remove the motherboard from the device.
  18. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, USB Port: Schritt 18, Bild 1 von 1
    • Once you've removed the motherboard, desolder the four contact points on the USB connector.
    • For proper technique on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the USB port from the device.
    • Resolder the new USB connector in the same place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nate Blake
507 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S2-G6, White Winter 2020 Mitglied von Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
4 Mitglieder
13 Anleitungen geschrieben
2 Kommentare
what is the replacement part number?
Edwin Maynard - Antwort
Was anyone able to find a part number for the specific USB ports?
Greg - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 34
Insgesamt: 2,818
