Einleitung
Use this guide to help you remove and replace the Solid State Drive (SSD) in your ThinkPad T490. This process is often done to upgrade the SSD when your computer starts running at a slower capacity, allowing for better overall running performance. Keep in mind that a thermal pad helps the SSD manage heat more efficiently. Be sure to save the original thermal pad or have a new one on hand.
Before starting this repair, back up the data on your current SSD if possible. If you’re replacing the SSD that has your operating system installed, consider using a disk cloning unit to easily transfer your data to the new SSD.
Was du brauchst
Loosen the screws from the base plate.
Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
Once the screws have been loosened, start to remove the base plate.
Insert the iFixit opening tool into the space between the base plate and the chassis.
Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
Fully remove the base .
Grab the edge of the cover and lift the cover away from you.
Grab the battery pull-tab at the top of the connector plugin.
Pull the connector straight out in the direction toward the cable.
Use a Phillips #1 screwdriver to remove the 3.7 mm Phillips screw securing the SSD.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
