Einleitung
Use this guide to replace a full or faulty solid state drive in your Lenovo ThinkPad X1 Carbon 7th Generation laptop.
The SSD is a piece of hardware that stores and retrieves data in your computer. A faulty SSD may cause your laptop to produce irregular noises, continuous crashes, and/or error messages like “file not found” or “Windows detected a hard disk problem.”
Before using this guide, make sure to review the troubleshooting page to diagnose your laptop’s problem and find the best solution.
Make sure to back up your hard drive before replacing it so you do not lose data while doing the replacement. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Restart the computer. When the Lenovo logo is displayed, immediately press enter, then press F1 to enter the BIOS Setup Utility
Use the arrow keys to select Config→Power.
Select "Disable Built-in Battery".
The battery will be re-enabled when the charger is connected.
Flip the laptop over on a flat surface with the back panel facing up.
Remove the five 5 mm Phillips #0 screws from the edge of the back panel.
Insert an opening tool between the back panel and edge. Maneuver the tool around the panel, disconnecting the clips holding the panel in place.
Gently pull back the black plastic flap covering the SSD to reveal the M.2 PCIe slot and mounting screw.
Remove the 3mm screw securing the SSD to the motherboard with a Phillips #0 screwdriver.
4 weitere Nutzer haben diese Anleitung absolviert.
