Einleitung
Use this guide to remove and replace the Solid State Drive (SSD) in your Lenovo ThinkPad X1.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Was du brauchst
Use a Phillips #1 screwdriver to loosen the five captive screws holding the back cover.
Insert an opening pick between a corner of the back cover and the chassis, near a hinge.
Pry upward to release the retaining clips.
Repeat this process for the opposite corner.
Insert the opening pick between the cover and the body.
Pry upward and release all of the retaining clips.
Use a Phillips #1 screwdriver to remove the six 4.9 mm screws securing the battery to the laptop chassis.
Grip the corners of the battery.
Pull and lift the battery of its recess and remove it.
Use your Phillips screwdriver to remove the two 3.5 mm screws holding the metal SSD cover.
Grip the edges of the SSD near the screw indent.
Pull the SSD straight out of its socket and remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon community for help.
2 weitere Personen haben diese Anleitung absolviert.
