Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: Schritt 1, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: Schritt 1, Bild 2 von 2
    • Orient the laptop so that it is bottom up, and the track pad is closet to you.
    • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen but will stay attached to the cover.
    • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
  2. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #00 head screwdriver, remove the 3mm screw holding the wireless adapter to the motherboard.
  3. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: Schritt 3, Bild 3 von 3
    • Slide the chip to the right carefully until the wireless adapter pops out.
    • Disconnect the grey and black wires by lifting them off straight up until they pop off the wireless adapter.
    • The chip should be completely removed from the computer and you are done.
Abschluss
Cal Poly, Team S7-G3, Regan Winter 2020 Mitglied von Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Hi, does the Lenovo X1 Extreme Gen 1 support Wifi 6 or 6e? If so what which card?
I tried the:
"AX210NGW WiFi Card, Wi-Fi 6E 11AX Wireless Module Expand to 6GHz MU-MIMO Tri-Band Bluetooth 5.3 Internal Network Adapter for Laptop, Support Windows 10/11 64bit, M.2/NGFF"
Wifi worked but Bluetooth wasn't recognized.
Captainturk - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 94
Insgesamt: 2,414
