Einleitung
If you need to access your laptops trackpad, or need to replace your laptops battery please refer to this guide. This guide does not require any difficult or complicated steps. Do exercise caution before beginning this guide by ensuring that the laptop is unplugged and turned off. To complete the removal and/or the replacement of your battery, you will need a plastic opening tool, a Phillips #0 screwdriver, and a pair of tweezers.
Was du brauchst
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
