Einleitung
This guide shows you how to replace the Lenovo Yoga 720 15-IKB (88YG7000828) fan. This laptop is very similar to the Lenovo Yoga 720 13-inch , the Yoga 710, and the Yoga 730. The fan replacement for all of these models will be similar. A faulty fan can cause the laptop to overheat, slowing down performance. These symptoms are further explained on the troubleshooting page. The thermal paste is located underneath the fan. Refer to this guide if you would like to replace the thermal paste.
Was du brauchst
Power off the device before starting.
Flip the device over with the hinges facing away from you.
Remove seven 5.0 mm Torx T5 screws.
Remove three 9.5 mm Torx T5 screws.
Pry around the edges from one side to another with a plastic opening tool.
Lift the case from the front until you feel resistance.
Pull the cover towards you, away from the hinges.
Completely lift off the cover.
Remove the six 5.2mm Torx T5 screws holding the fan in place.
Remove the five 5.0mm Torx T5 screws holding the fan in place.
7 weitere Personen haben diese Anleitung absolviert.
