Zum Hauptinhalt wechseln
Levoit Core 300-RAC Control Board Replacement
Was du brauchst
  1. Levoit Core 300-RAC Control Board Replacement, Control Board: Schritt 1, Bild 1 von 3 Levoit Core 300-RAC Control Board Replacement, Control Board: Schritt 1, Bild 2 von 3 Levoit Core 300-RAC Control Board Replacement, Control Board: Schritt 1, Bild 3 von 3
    • Make sure the device is turned off and unplugged before disassembling it.
    • Insert the Jimmy between the gray grille cover and the top of the device.
    • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
    • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
    • Remove the grille cover gently as it is connected by a ribbon cable.
    • Be careful not to put too much strain on the ribbon cable as it may break.
    Frag FixBot
    Kommentar hinzufügen
  2. Levoit Core 300-RAC Control Board Replacement: Schritt 2, Bild 1 von 3 Levoit Core 300-RAC Control Board Replacement: Schritt 2, Bild 2 von 3 Levoit Core 300-RAC Control Board Replacement: Schritt 2, Bild 3 von 3
    • Squeeze the tab on the connector to release the bundled cable from the control board.
    • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
    Frag FixBot
  3. Levoit Core 300-RAC Control Board Replacement: Schritt 3, Bild 1 von 2 Levoit Core 300-RAC Control Board Replacement: Schritt 3, Bild 2 von 2
    • Gently bend the gray plastic cover to release the control board.
    • There are several hard tabs holding the control board in place.
    Frag FixBot
  4. Levoit Core 300-RAC Control Board Replacement: Schritt 4, Bild 1 von 3 Levoit Core 300-RAC Control Board Replacement: Schritt 4, Bild 2 von 3 Levoit Core 300-RAC Control Board Replacement: Schritt 4, Bild 3 von 3
    • Lift the control board from the gray plastic cover.
    • Take note of the orientations of the buttons, as that will help during reassembly.
    Frag FixBot
Abschluss
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Mitglied von UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 81
Insgesamt: 1,847
