Zum Hauptinhalt wechseln
Levoit Core 300-RAC Fan Replacement
Was du brauchst
  1. Levoit Core 300-RAC Fan Replacement, Air Filter: Schritt 1, Bild 1 von 2 Levoit Core 300-RAC Fan Replacement, Air Filter: Schritt 1, Bild 2 von 2
    • Make sure your device is turned off and unplugged for safety.
    • Turn the Levoit Core 300-RAC over so the bottom is facing up.
    Frag FixBot
    Kommentar hinzufügen
  2. Levoit Core 300-RAC Fan Replacement: Schritt 2, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 2, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 2, Bild 3 von 3
    • Turn the bottom cover counterclockwise and lift it off to remove it.
    • The cover does not "snap" on or off when turned.
    Frag FixBot
  3. Levoit Core 300-RAC Fan Replacement: Schritt 3, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 3, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 3, Bild 3 von 3
    • Lift the filter straight up and out of the device.
    Frag FixBot
  4. Levoit Core 300-RAC Fan Replacement, Fan: Schritt 4, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement, Fan: Schritt 4, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement, Fan: Schritt 4, Bild 3 von 3
    • Use a Phillips #2 screwdriver to remove the four screws that secure the gray lid towards the base of the device.
    • Set the screws aside in a safe place.
    Frag FixBot
  5. Levoit Core 300-RAC Fan Replacement: Schritt 5, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 5, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 5, Bild 3 von 3
    • Use a metal spudger or Jimmy to gently pry between the four white tabs and the white housing to release the outer housing.
    • Gently pulling up on the outer housing can prevent the clips from resetting.
    Frag FixBot
  6. Levoit Core 300-RAC Fan Replacement: Schritt 6, Bild 1 von 2 Levoit Core 300-RAC Fan Replacement: Schritt 6, Bild 2 von 2
    • Remove the outer white housing and set it to the side.
    • The power cord is fed through a hole in the side of this housing, so it has to sit right next to the device.
    Frag FixBot
  7. Levoit Core 300-RAC Fan Replacement: Schritt 7, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 7, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 7, Bild 3 von 3
    • Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
    Frag FixBot
  8. Levoit Core 300-RAC Fan Replacement: Schritt 8, Bild 1 von 2 Levoit Core 300-RAC Fan Replacement: Schritt 8, Bild 2 von 2
    • Remove the four Phillips #2 screws securing the gray face plate.
    Frag FixBot
  9. Levoit Core 300-RAC Fan Replacement: Schritt 9, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 9, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 9, Bild 3 von 3
    • Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
    • Lift it out.
    Frag FixBot
  10. Levoit Core 300-RAC Fan Replacement: Schritt 10, Bild 1 von 1
    • Turn your device over so it is upright again.
    Frag FixBot
  11. Levoit Core 300-RAC Fan Replacement: Schritt 11, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 11, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 11, Bild 3 von 3
    • Insert the Jimmy between the gray grille cover and the top of the device.
    • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
    • Take note of the placement of the tabs, as they are keyed and need to go back in the exact way they came out.
    • Remove the grille cover gently as it is connected by a ribbon cable.
    • Be careful not to put too much strain on the ribbon cable as it may break.
    Frag FixBot
  12. Levoit Core 300-RAC Fan Replacement: Schritt 12, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 12, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 12, Bild 3 von 3
    • Squeeze the tab on the connector to release the bundled cable from the control board.
    • The connector should come out fairly easily, do not force it. Pulling too hard could damage the connector.
    Frag FixBot
  13. Levoit Core 300-RAC Fan Replacement: Schritt 13, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 13, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 13, Bild 3 von 3
    • Insert a spudger or Jimmy into the four tabs to release them from holding the outer white housing to the inner black core.
    • Remove the white outer housing.
    Frag FixBot
  14. Levoit Core 300-RAC Fan Replacement: Schritt 14, Bild 1 von 1
    • Flip your device over again so the fan is facing up.
    Frag FixBot
  15. Levoit Core 300-RAC Fan Replacement: Schritt 15, Bild 1 von 2 Levoit Core 300-RAC Fan Replacement: Schritt 15, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the three screws on the upper portion of the black housing.
    Frag FixBot
  16. Levoit Core 300-RAC Fan Replacement: Schritt 16, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 16, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 16, Bild 3 von 3
    • Remove the upper portion of the black housing.
    Frag FixBot
  17. Levoit Core 300-RAC Fan Replacement: Schritt 17, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 17, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 17, Bild 3 von 3
    • Use a 13mm socket wrench with an extension to remove the nut holding the fan in place and remove all hardware from the threaded shaft.
    • There should be a nylon-insert lock nut, a flat washer, and a split ring washer. Set these aside in a safe location.
    Frag FixBot
  18. Levoit Core 300-RAC Fan Replacement: Schritt 18, Bild 1 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 18, Bild 2 von 3 Levoit Core 300-RAC Fan Replacement: Schritt 18, Bild 3 von 3
    • Lift the fan up and off of the threaded shaft.
    • There is another washer underneath the fan, leave it in place for the replacement fan.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Mitglied von UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 62
Letzte 30 Tage: 232
Insgesamt: 6,501
