Einleitung
A non-functioning fan can significantly reduce your Levoit Core 300-RAC air purifier’s performance. If your device isn’t outputting enough air or the fan isn’t spinning, it may be time to clean or replace it.
This guide demonstrates how to replace the fan. You can also use it to access the fan for cleaning with an air blower and brush. Cleaning the fan may improve performance and help avoid replacement.
Before you begin, ensure the device is turned off and unplugged.
Was du brauchst
Use a Phillips #2 screwdriver to remove the four screws that secure the gray lid towards the base of the device.
Use a metal spudger or Jimmy to gently pry between the four white tabs and the white housing to release the outer housing.
Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
Lift it out.
Insert the Jimmy between the gray grille cover and the top of the device.
Work your way around the grille cover with the Jimmy to release the clips holding it in place.
Remove the grille cover gently as it is connected by a ribbon cable.
Squeeze the tab on the connector to release the bundled cable from the control board.
Insert a spudger or Jimmy into the four tabs to release them from holding the outer white housing to the inner black core.
Remove the white outer housing.
Use a Phillips #2 screwdriver to remove the three screws on the upper portion of the black housing.
Use a 13mm socket wrench with an extension to remove the nut holding the fan in place and remove all hardware from the threaded shaft.
Eine weitere Person hat diese Anleitung absolviert.
