Zum Hauptinhalt wechseln
Logitech G Cloud L2-R2 Trigger Replacement
Was du brauchst
  1. Logitech G Cloud L2-R2 Trigger Replacement, Case: Schritt 1, Bild 1 von 2 Logitech G Cloud L2-R2 Trigger Replacement, Case: Schritt 1, Bild 2 von 2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
    Frag FixBot
    Kommentar hinzufügen
  2. Logitech G Cloud L2-R2 Trigger Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
    Frag FixBot
  3. Logitech G Cloud L2-R2 Trigger Replacement: Schritt 3, Bild 1 von 2 Logitech G Cloud L2-R2 Trigger Replacement: Schritt 3, Bild 2 von 2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
    Frag FixBot
  4. Logitech G Cloud L2-R2 Trigger Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
    Frag FixBot
  5. Logitech G Cloud L2-R2 Trigger Replacement: Schritt 5, Bild 1 von 2 Logitech G Cloud L2-R2 Trigger Replacement: Schritt 5, Bild 2 von 2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
    Frag FixBot
  6. Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: Schritt 6, Bild 1 von 2 Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: Schritt 6, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws that secure the L2 and R2 triggers.
    • Pop the L2 and R2 triggers out with your fingers.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 70
Insgesamt: 635
