Zum Hauptinhalt wechseln
Logitech G305 Mouse Left Clicker Replacement
Was du brauchst
    1. Logitech G305 Mouse Left Clicker Replacement, Left Clicker: Schritt 1, Bild 1 von 2 Logitech G305 Mouse Left Clicker Replacement, Left Clicker: Schritt 1, Bild 2 von 2
      • Remove the battery cover by pressing the top of the cover and pulling it downwards.
      • Remove the battery.
      Frag FixBot
      Kommentar hinzufügen
    2. Logitech G305 Mouse Left Clicker Replacement: Schritt 2, Bild 1 von 3 Logitech G305 Mouse Left Clicker Replacement: Schritt 2, Bild 2 von 3 Logitech G305 Mouse Left Clicker Replacement: Schritt 2, Bild 3 von 3
      • Carefully use a box cutter to follow the grooves of the mouse skate pads and slowly lift them off.
      • Use a Phillips #00 screwdriver to remove the four screws.
      Frag FixBot
    3. Logitech G305 Mouse Left Clicker Replacement: Schritt 3, Bild 1 von 2 Logitech G305 Mouse Left Clicker Replacement: Schritt 3, Bild 2 von 2
      • Use a spudger to carefully separate the two halves of the mouse near the battery compartment.
      Frag FixBot
    4. Logitech G305 Mouse Left Clicker Replacement: Schritt 4, Bild 1 von 2 Logitech G305 Mouse Left Clicker Replacement: Schritt 4, Bild 2 von 2
      • Open the compartment and slowly separate the halves until the internal wires are exposed.
      • Carefully disconnect the two wires by hand from the base.
      • The wires are fragile and require careful handling.
      Frag FixBot
    5. Logitech G305 Mouse Left Clicker Replacement: Schritt 5, Bild 1 von 3 Logitech G305 Mouse Left Clicker Replacement: Schritt 5, Bild 2 von 3 Logitech G305 Mouse Left Clicker Replacement: Schritt 5, Bild 3 von 3
      • Remove the three screws from the center battery compartment using a Phillips #00 screwdriver.
      • Remove the two screws securing the left clicker.
      Frag FixBot
    6. Logitech G305 Mouse Left Clicker Replacement: Schritt 6, Bild 1 von 2 Logitech G305 Mouse Left Clicker Replacement: Schritt 6, Bild 2 von 2
      • Lift the battery compartment to gain easy access to the clicker.
      • Lift the battery compartment with care because of fragile wires.
      • Remove the left clicker.
      Frag FixBot
    7. Logitech G305 Mouse Left Clicker Replacement: Schritt 7, Bild 1 von 2 Logitech G305 Mouse Left Clicker Replacement: Schritt 7, Bild 2 von 2
      • Insert the replacement component and slide it into position until it securely clicks into place.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
CSU Los Angeles, Team 8-9, Grodsky Fall 2025 Mitglied von CSU Los Angeles, Team 8-9, Grodsky Fall 2025
CSULA-GRODSKY-F25S8G9
2 Mitglieder
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 88
Letzte 30 Tage: 341
Insgesamt: 2,584
