Zum Hauptinhalt wechseln
Logitech G602 Scroll Wheel Replacement
Was du brauchst
    1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: Schritt 1, Bild 1 von 1
      • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
      Frag FixBot
      Kommentar hinzufügen
    2. Logitech G602 Scroll Wheel Replacement: Schritt 2, Bild 1 von 1
      • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
      Frag FixBot
    3. Logitech G602 Scroll Wheel Replacement: Schritt 3, Bild 1 von 2 Logitech G602 Scroll Wheel Replacement: Schritt 3, Bild 2 von 2
      • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
      Frag FixBot
    4. Logitech G602 Scroll Wheel Replacement: Schritt 4, Bild 1 von 1
      • Use the black spudger to move the tip of the metal spring off of the wheel.
      • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
      Frag FixBot
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
4 Kommentare zur Anleitung
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - Antwort Teilen
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - Antwort Teilen
"Logitech G602 Scroll Wheel Replacement" - completely misleading title. Thanks for wasting people's time.
Myshka - Antwort Teilen
Merci pour les recommandations. Elles m'ont permis de voir qu'il y avait un fil dessoudé. ça m'aurait bien gêné d'en racheter une autre.
Didielus - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 21
Letzte 30 Tage: 83
Insgesamt: 10,670
