Zum Hauptinhalt wechseln
Logitech MBJ58 Mouse Resistance Spring Replacement
Was du brauchst
  1. Logitech MBJ58 Mouse Resistance Spring Replacement, Top cover: Schritt 1, Bild 1 von 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    Frag FixBot
    Kommentar hinzufügen
  2. Logitech MBJ58 Mouse Resistance Spring Replacement: Schritt 2, Bild 1 von 2 Logitech MBJ58 Mouse Resistance Spring Replacement: Schritt 2, Bild 2 von 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    Frag FixBot
  3. Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: Schritt 3, Bild 1 von 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: Schritt 3, Bild 2 von 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: Schritt 3, Bild 3 von 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    Frag FixBot
  4. Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: Schritt 4, Bild 1 von 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: Schritt 4, Bild 2 von 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    Frag FixBot
  5. Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: Schritt 5, Bild 1 von 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: Schritt 5, Bild 2 von 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    Frag FixBot
  6. Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: Schritt 6, Bild 1 von 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: Schritt 6, Bild 2 von 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: Schritt 6, Bild 3 von 3
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
    Frag FixBot
  7. Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: Schritt 7, Bild 1 von 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: Schritt 7, Bild 2 von 2
    • Grasp the top of the resistance spring and pull it towards yourself, letting the hook slide out of its hole.
    Frag FixBot
  8. Logitech MBJ58 Mouse Resistance Spring Replacement: Schritt 8, Bild 1 von 1
    • Insert the hooked section of the replacement spring into the corresponding hole on the mount.
    Frag FixBot
Abschluss
15 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 5-14, Forte Winter 2013 Mitglied von Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Mitglieder
23 Anleitungen geschrieben
10 Kommentare zur Anleitung
This mouse was also available from Dell as an OEM device under the model name "M-UVDEL1". Hopefully the Google juice will help folks repair their devices. I know I would have spent far more time than I did if it weren't for the photos on how to put the spring back. Thanks Maximilian!
Bastien Nocera - Antwort Teilen
The spring installation details were lifesavers. Thank you!
LB
byard - Antwort Teilen
thank you! could not have done it without your help.
taiyo_yuden_dvd - Antwort Teilen
Brilliant. Thanks. Easy once you know how. The springs were the hard part.
Charles Thomson - Antwort Teilen
Thank you so much!! You made it very easy and quick!
vulcanmeister - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 85
Insgesamt: 13,548
