Einleitung
Use this guide remove and replace worn out mouse feet (also called skates or pads) on the bottom of a Logitech MX Vertical wireless mouse.
If thoroughly heated, the mouse feet can be cleanly removed, but you may need replacement feet if one rips or some of its adhesive is left behind.
Was du brauchst
Before you begin, flip the mouse's power switch into the OFF position.
Heat an iOpener and apply it to the feet on the mouse's underside for about two minutes.
Insert one arm of a pair of sharp tweezers underneath the end of one foot.
Grip the foot and begin to peel it away from the bottom of the mouse.
Use a pair of tweezers to peel the foot away from the mouse to completely remove it.
Place the foot adhesive-side up on a clean surface.
Insert a tweezer arm underneath the end of the second foot.
Peel the foot away from the mouse to completely remove it.
5 weitere Personen haben diese Anleitung absolviert.
