Einleitung
Use this guide to replace a noisy MacBook Air 13" Early 2015 fan, or simply remove it for cleaning.
Ersatzteile
Einführungsvideo
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
Remove the I/O board cable.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Remove the following three screws securing the fan to the upper case:
One 5.2 mm T5 Torx screw
One 3.3 mm T5 Torx screw
One 4.4 mm T5 Torx screw with a short head
Lift the fan from the I/O board side and pull it free from the upper case.
Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
38 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
Hello! I just broke the flap/hinge on the ZIF socket connecting the fan ribbon. What do I do now? Is a replacement ZIF socket available?
The zif connector just detached from the board when attempting to open the hinge with spudger. I’ve tried to solder the zif connector back to the board but the connector is so small that I haven’t been successful.
