Zum Hauptinhalt wechseln
Magic Trackpad Batterie auswechseln
Was du brauchst
    1. Magic Trackpad Batterie auswechseln, Batterien: Schritt 1, Bild 1 von 2 Magic Trackpad Batterie auswechseln, Batterien: Schritt 1, Bild 2 von 2
      • Drehe den Batteriefachdeckel mit dem Spudger oder einer Münze auf.
      Frag FixBot
      Kommentar hinzufügen
    2. Magic Trackpad Batterie auswechseln: Schritt 2, Bild 1 von 1
      • Lasse die AA- Batterien herausgleiten.
      Frag FixBot
Abschluss
Um dein Gerät wieder zusammenbauen, folge den Schritten in umgekehrter Reihenfolge.
3 weitere Personen haben diese Anleitung absolviert.
en de
100%
VauWeh hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Ronnie
3.851 Reputation
5 Anleitungen geschrieben
4 Kommentare zur Anleitung
Hello there, is the Trackpad destroyed by misplacing (wrong polarity) the batteries?
Toto1411 - Antwort Teilen
I recently found a Magic Trackpad on a junk pile, to find that the batteries are corroded and won’t come out.
I poured a small amount of isopropyl alcohol in the battery cylider, pried with a thin plastic pick and banged it against a table to get out the first battery, but the second one doesn’t want to move.
Any suggestions for how to get it out without destroying the device? The only thing I can think of would be to crazy-glue a thin rod to the top of the battery, maybe pour in some alcohol, and pull/wiggle the battery until it comes out. I’m afraid that any kind of stronger solvent will cause real damage.
Opinions?
shamino - Antwort Teilen
The best solvent for leaked alkaline batteries is… tap water!
michel.firholz - Antwort Teilen
I had corroded batteries in my Magic Keyboard. Exact same construction. I fashioned a thin blade from an aluminum can. It had enough column strength to slide between the battery and the aluminum battery compartment and with different solvents I was able to free the batteries. Now I have a trackpad that I am trying to recondition but not so easy. IPA and WD40 did not free the batteries this time, about to try dilute vinegar.
Eric Andersen - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 41
Letzte 30 Tage: 189
Insgesamt: 18,410
