Zum Hauptinhalt wechseln
Main Click Buttons
Was du brauchst
    1. Main Click Buttons, Click Buttons: Schritt 1, Bild 1 von 2 Main Click Buttons, Click Buttons: Schritt 1, Bild 2 von 2
      • Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
      Frag FixBot
      Kommentar hinzufügen
    2. Main Click Buttons: Schritt 2, Bild 1 von 2 Main Click Buttons: Schritt 2, Bild 2 von 2
      • Use a #00 screwdriver (3x5mm) to unscrew all 6 screws from under the mouse feet.
      Frag FixBot
    3. Main Click Buttons: Schritt 3, Bild 1 von 2 Main Click Buttons: Schritt 3, Bild 2 von 2
      • Use a blue spudger to open the bottom battery port.
      Frag FixBot
    4. Main Click Buttons: Schritt 4, Bild 1 von 2 Main Click Buttons: Schritt 4, Bild 2 von 2
      • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the internal hardware.
      Frag FixBot
    5. Main Click Buttons: Schritt 5, Bild 1 von 3 Main Click Buttons: Schritt 5, Bild 2 von 3 Main Click Buttons: Schritt 5, Bild 3 von 3
      • Use pliers to grip and remove the black covers over the button — the black cover and the button, a small white plastic piece, should come off).
      Frag FixBot
Abschluss
18 weitere Personen haben diese Anleitung absolviert.
6 Kommentare zur Anleitung
how are you supposed to put the feet back?
Owen Yuen - Antwort Teilen
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
Erick Alonso Duque - Antwort Teilen
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
Russell Reeling - Antwort Teilen
Are the side buttons the same?
S I - Antwort Teilen
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
Nonalbert Noneinstein - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 43
Letzte 30 Tage: 171
Insgesamt: 25,698
