Zum Hauptinhalt wechseln
Merch Source Projector Entertainment II Light Bulb Replacement
Was du brauchst
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: Schritt 1, Bild 1 von 2 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: Schritt 1, Bild 2 von 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Frag FixBot
      Kommentar hinzufügen
    2. Merch Source Projector Entertainment II Light Bulb Replacement: Schritt 2, Bild 1 von 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Frag FixBot
    3. Merch Source Projector Entertainment II Light Bulb Replacement: Schritt 3, Bild 1 von 2 Merch Source Projector Entertainment II Light Bulb Replacement: Schritt 3, Bild 2 von 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Frag FixBot
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: Schritt 4, Bild 1 von 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: Schritt 4, Bild 2 von 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: Schritt 4, Bild 3 von 3
      • Remove the light bulb from its housing unit.
      • Do not damage the 2 white cables leading into the light bulb panel.
      Frag FixBot
    2. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: Schritt 5, Bild 1 von 2 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: Schritt 5, Bild 2 von 2
      • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
      • The light blub is held into the socket with prongs, and should easily pull straight out.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 18-3, Maness Winter 2015 Mitglied von Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Mitglieder
8 Anleitungen geschrieben
1 Kommentar zur Anleitung
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 40
Insgesamt: 2,650
