Zum Hauptinhalt wechseln
Microsoft Surface Pro 2 Camera Replacement
Was du brauchst
  1. Microsoft Surface Pro 2 Camera Replacement, LCD Display: Schritt 1, Bild 1 von 2 Microsoft Surface Pro 2 Camera Replacement, LCD Display: Schritt 1, Bild 2 von 2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
    Frag FixBot
    Kommentar hinzufügen
  2. Microsoft Surface Pro 2 Camera Replacement: Schritt 2, Bild 1 von 1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
    Frag FixBot
  3. Microsoft Surface Pro 2 Camera Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
    Frag FixBot
  4. Microsoft Surface Pro 2 Camera Replacement: Schritt 4, Bild 1 von 3 Microsoft Surface Pro 2 Camera Replacement: Schritt 4, Bild 2 von 3 Microsoft Surface Pro 2 Camera Replacement: Schritt 4, Bild 3 von 3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
    Frag FixBot
  5. Microsoft Surface Pro 2 Camera Replacement, Motherboard: Schritt 5, Bild 1 von 3 Microsoft Surface Pro 2 Camera Replacement, Motherboard: Schritt 5, Bild 2 von 3 Microsoft Surface Pro 2 Camera Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
    • Remove the 22 screws on the bezel.
    • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
    • The three different torx screws used are T3, T4, and T5.
    Frag FixBot
  6. Microsoft Surface Pro 2 Camera Replacement: Schritt 6, Bild 1 von 3 Microsoft Surface Pro 2 Camera Replacement: Schritt 6, Bild 2 von 3 Microsoft Surface Pro 2 Camera Replacement: Schritt 6, Bild 3 von 3
    • Once the brackets are removed, set them aside.
    • The motherboard itself also has screws.
    • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
    • View the attached photo of a screw diagram to help keep track of your screws.
    Frag FixBot
  7. Microsoft Surface Pro 2 Camera Replacement: Schritt 7, Bild 1 von 3 Microsoft Surface Pro 2 Camera Replacement: Schritt 7, Bild 2 von 3 Microsoft Surface Pro 2 Camera Replacement: Schritt 7, Bild 3 von 3
    • You have now completely removed the motherboard, and it should look like the pictures shown.
    • Be sure to be cautious with all the connections with the cables on the motherboard.
    Frag FixBot
  8. Microsoft Surface Pro 2 Camera Replacement, Camera: Schritt 8, Bild 1 von 1
    • Remove the ribbon that the spudger is touching in the picture.
    • Remove the front-facing camera.
    Frag FixBot
  9. Microsoft Surface Pro 2 Camera Replacement: Schritt 9, Bild 1 von 1
    Frag FixBot
  10. Microsoft Surface Pro 2 Camera Replacement: Schritt 10, Bild 1 von 2 Microsoft Surface Pro 2 Camera Replacement: Schritt 10, Bild 2 von 2
    Frag FixBot
Abschluss
abdulhameeda
108 Reputation
1 Anleitung geschrieben
USF Tampa, Team 6-2, Remmell Fall 2016 Mitglied von USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 1,356
