Einleitung
Follow this guide to replace the kickstand on your Microsoft Surface Pro 4.
Was du brauchst
Place your device screen-down on a clean work surface.
Open the kickstand as wide as it is designed to go (about 135 degrees).
Use a T5 Torx screwdriver to remove the two 3.3 mm screws securing each hinge to the kickstand.
Press the kickstand from directly behind the hinges and close it fully.
Pull the kickstand straight out from the bottom of the device.
Install your new kickstand by inserting its two appendages into the back of the device.
Press your new kickstand towards the top of the device until it is fully inserted.
Open the kickstand 180 degrees to expose the hinges.
To open the hinge, insert your T5 Torx screwdriver into one of the screw holes and gently pry towards the top of your device until the hinge is exposed.
6 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Is there a way to fix or replace the hinge? The kickstand on my Surface Pro is fine but the left hinge broke so now it won’t hold it up
Joel - did you find a solution? My left hinge broke a week ago and I’m looking for a solution. Thanks!
I’m sorry for the delayed reply. I didn’t check on the hinges when I was working on the guide and unfortunately I don’t have the device still. In my online research, I found that the hinges are replaceable but I wasn’t able to find replacement parts.
