Zum Hauptinhalt wechseln
Monster DNA Wire Replacement
Was du brauchst
    1. Monster DNA Wire Replacement, Wire: Schritt 1, Bild 1 von 1
      • Take off the ear cushions by pulling on the sides.
      Frag FixBot
      Kommentar hinzufügen
    2. Monster DNA Wire Replacement: Schritt 2, Bild 1 von 1
      • Use a Phillips #2 screwdriver to unscrew the three 5mm screws that secure the speaker cover.
      Frag FixBot
    3. Monster DNA Wire Replacement: Schritt 3, Bild 1 von 1
      • Use a plastic opening tool or a metal spudger to pry off the plate
      • Be careful as too much force may cause damage to your headphones.
      Frag FixBot
    4. Monster DNA Wire Replacement: Schritt 4, Bild 1 von 1
      • Once the loose wire or wires are located on the back of the speaker, use a soldering iron to attach the loose wire back onto the speaker.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team S4-G5, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S4-G5, Julie Spring 2017
UMASSD-JULIE-S17S4G5
4 Mitglieder
12 Anleitungen geschrieben
2 Kommentare zur Anleitung
any ways on being able to know which side its on in particular without having to open both sides?
Finnlay Worchurst - Antwort Teilen
I broke the plate which holds the ear muffs on, by following these directions.
On Step 3, you have the spudger in the wrong location. You are supposed to put the prying bar or spudger before or after the silver ring which acts as a spacer for the speaker housing. I like to pry in the space between the silver ring and the audio jack.
Pics look good but you will have replace the one in step 3 showing the correct location to pry from. Others too will brake the same ring I did hence your warning about damage to the headphones if applying too much pressure.
Dan
Dan Daley - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 52
Insgesamt: 4,451
