Zum Hauptinhalt wechseln
Motion Computing LE1600 Bluetooth Module Replacement
Was du brauchst
    1. Motion Computing LE1600 Bluetooth Module Replacement, Battery: Schritt 1, Bild 1 von 1
      • Turn the device so the screen is facing down.
      Frag FixBot
      Kommentar hinzufügen
    2. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 2, Bild 1 von 2 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 2, Bild 2 von 2
      • Slide the battery lock switch next to the power slider to the unlocked position.
      Frag FixBot
    3. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 3, Bild 1 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 3, Bild 2 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 3, Bild 3 von 3
      • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
      • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
      Frag FixBot
    1. Motion Computing LE1600 Bluetooth Module Replacement, Bluetooth Module: Schritt 4, Bild 1 von 1
      • Unscrew hard drive panel using a Phillips head #1 screwdriver.
      • (Our device was not given to us with a hard drive or a hard drive panel)
      Frag FixBot
    2. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 5, Bild 1 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 5, Bild 2 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 5, Bild 3 von 3
      • Pull clear plastic tab to detach hard drive from tablet.
      Frag FixBot
    3. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 6, Bild 1 von 2 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 6, Bild 2 von 2
      • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
      Frag FixBot
    4. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 7, Bild 1 von 1
      • Pull the brown tabs to disconnect the white ribbon cable on the other side.
      Frag FixBot
    5. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 8, Bild 1 von 2 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 8, Bild 2 von 2
      • Caution: do not pull on the wires, instead pull from the plastic connectors.
      • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
      Frag FixBot
    6. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 9, Bild 1 von 1
      • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
      Frag FixBot
    7. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 10, Bild 1 von 1
      • Using a spudger, press in the five tabs on the side where the battery was.
      • This should separate the two halves of the device. Carefully set the side with the display off to the side.
      Frag FixBot
    8. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 11, Bild 1 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 11, Bild 2 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 11, Bild 3 von 3
      • Locate the Bluetooth board.
      • Disconnect the ribbon cable by pulling on the plastic connector.
      Frag FixBot
    9. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 12, Bild 1 von 2 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 12, Bild 2 von 2
      • Unscrew the 4mm screw holding the board onto the tablet.
      • Lift the board out of the tablet and carefully set it aside.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 15-14, Forte Spring 2012 Mitglied von Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
thanks for the help
Lawrence V Lang - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 64
Insgesamt: 2,886
