Zum Hauptinhalt wechseln
Nexus 10 Display Replacement
Was du brauchst
    1. Nexus 10 Display Replacement, Battery: Schritt 1, Bild 1 von 3 Nexus 10 Display Replacement, Battery: Schritt 1, Bild 2 von 3 Nexus 10 Display Replacement, Battery: Schritt 1, Bild 3 von 3
      • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
      Frag FixBot
      Kommentar hinzufügen
    2. Nexus 10 Display Replacement: Schritt 2, Bild 1 von 1
      • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
      Frag FixBot
    3. Nexus 10 Display Replacement: Schritt 3, Bild 1 von 3 Nexus 10 Display Replacement: Schritt 3, Bild 2 von 3 Nexus 10 Display Replacement: Schritt 3, Bild 3 von 3
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
      Frag FixBot
    4. Nexus 10 Display Replacement: Schritt 4, Bild 1 von 3 Nexus 10 Display Replacement: Schritt 4, Bild 2 von 3 Nexus 10 Display Replacement: Schritt 4, Bild 3 von 3
      • Detach the three connector ribbons passing over the battery using the plastic opening tool.
      Frag FixBot
    5. Nexus 10 Display Replacement: Schritt 5, Bild 1 von 1
      • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
      Frag FixBot
    6. Nexus 10 Display Replacement: Schritt 6, Bild 1 von 2 Nexus 10 Display Replacement: Schritt 6, Bild 2 von 2
      • Disconnect the battery by lifting it upward and pulling it away from the connector.
      Frag FixBot
    1. Nexus 10 Display Replacement, Headphone Jack: Schritt 7, Bild 1 von 1
      • Remove one screw on the logic board with a PH00 screwdriver.
      Frag FixBot
    2. Nexus 10 Display Replacement: Schritt 8, Bild 1 von 3 Nexus 10 Display Replacement: Schritt 8, Bild 2 von 3 Nexus 10 Display Replacement: Schritt 8, Bild 3 von 3
      • Disconnect right speaker connector ribbon from logic board.
      • Lift the speaker out by pulling up on its corner.
      Frag FixBot
    3. Nexus 10 Display Replacement: Schritt 9, Bild 1 von 3 Nexus 10 Display Replacement: Schritt 9, Bild 2 von 3 Nexus 10 Display Replacement: Schritt 9, Bild 3 von 3
      • Disconnect connectors around the perimeter of the motherboard.
      Frag FixBot
    4. Nexus 10 Display Replacement: Schritt 10, Bild 1 von 2 Nexus 10 Display Replacement: Schritt 10, Bild 2 von 2
      • Remove motherboard by gently pulling upward under its corner.
      Frag FixBot
    5. Nexus 10 Display Replacement: Schritt 11, Bild 1 von 1
      • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
      Frag FixBot
    6. Nexus 10 Display Replacement: Schritt 12, Bild 1 von 2 Nexus 10 Display Replacement: Schritt 12, Bild 2 von 2
      • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
      Frag FixBot
    7. Nexus 10 Display Replacement: Schritt 13, Bild 1 von 2 Nexus 10 Display Replacement: Schritt 13, Bild 2 von 2
      • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
      Frag FixBot
    8. Nexus 10 Display Replacement: Schritt 14, Bild 1 von 2 Nexus 10 Display Replacement: Schritt 14, Bild 2 von 2
      • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
      Frag FixBot
    1. Nexus 10 Display Replacement, Display: Schritt 15, Bild 1 von 2 Nexus 10 Display Replacement, Display: Schritt 15, Bild 2 von 2
      • Detach LCD connector ribbon by pressing upward on connector latch using a plastic opening tool.
      Frag FixBot
    2. Nexus 10 Display Replacement: Schritt 16, Bild 1 von 2 Nexus 10 Display Replacement: Schritt 16, Bild 2 von 2
      • Unscrew the two 2mm Phillips #00 screws holding the ribbon in place.
      • Remove the board by tilting it forward and pulling outward.
      Frag FixBot
    3. Nexus 10 Display Replacement: Schritt 17, Bild 1 von 1
      • Remove second speaker by gently tilting and pulling upward.
      Frag FixBot
    4. Nexus 10 Display Replacement: Schritt 18, Bild 1 von 3 Nexus 10 Display Replacement: Schritt 18, Bild 2 von 3 Nexus 10 Display Replacement: Schritt 18, Bild 3 von 3
      • Unscrew the two 2mm screws securing the micro HDMI connector with a #PH00 screwdriver.
      • Remove the connector by liberally applying upward pressure.
      Frag FixBot
    5. Nexus 10 Display Replacement: Schritt 19, Bild 1 von 3 Nexus 10 Display Replacement: Schritt 19, Bild 2 von 3 Nexus 10 Display Replacement: Schritt 19, Bild 3 von 3
      • Unscrew the 2mm Phillips #00 screw that holds the flash enclosure.
      • Remove the flash assembly with a plastic opening tool by lifting the assembly upward.
      Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 34-18, Maness Spring 2016 Mitglied von Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Mitglieder
15 Anleitungen geschrieben
4 Kommentare zur Anleitung
I’m waiting for the instructions regarding how to remove the old screen and insert the new - it seems to be missing
John Walker - Antwort Teilen
It seems you just have to buy a replacement for that whole front housing, including the screen assembly
Oliver Nichol - Antwort Teilen
Still waiting to see how the screen is remove
Frank - Antwort Teilen
he cambiado la bateria y he partido el presor negro del conector de LCD y no me me funciona, se puede comprar esa pieza negra?
Diego Mera - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 49
Insgesamt: 9,176
