Einleitung
Use this guide to replace the rear camera in your Nexus 6P smartphone. When reassembling your phone apply new adhesive where it is necessary.
Was du brauchst
Use a SIM card eject tool, to pop out and remove the SIM card tray.
Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
Slide the opening pick underneath the plastic cover to cut the adhesive.
Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
Pry off the glass cover.
Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
Insert a second opening pick and slide it to the top left corner.
Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
Remove the rear cover.
Unplug the antenna cable with tweezers.
Use a spudger to disconnect the display and battery flex cable.
Use a spudger to disconnect the main flex cable.
Pry up the motherboard with a spudger until you can get a good grip.
Remove the motherboard carefully.
Flip the motherboard and disconnect the rear camera flex cable with a spudger.
Carefully remove the rear camera with tweezers.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Any suggestions on where to source adhesive or what to use?
