Zum Hauptinhalt wechseln
Nikon Coolpix P90 Eyepiece Replacement
Was du brauchst
  1. Nikon Coolpix P90 Eyepiece Replacement, Camera Base: Schritt 1, Bild 1 von 3 Nikon Coolpix P90 Eyepiece Replacement, Camera Base: Schritt 1, Bild 2 von 3 Nikon Coolpix P90 Eyepiece Replacement, Camera Base: Schritt 1, Bild 3 von 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 Eyepiece Replacement, Eyepiece: Schritt 2, Bild 1 von 3 Nikon Coolpix P90 Eyepiece Replacement, Eyepiece: Schritt 2, Bild 2 von 3 Nikon Coolpix P90 Eyepiece Replacement, Eyepiece: Schritt 2, Bild 3 von 3
    • Use a Phillips #000 Precision Screwdriver for all of the following steps.
    • On the bottom side of the camera, remove two 4.5 mm screws holding the bottom case in place.
    • On the right side of the camera, remove two 4.5 mm screws.
    • On the right side of the camera, remove the single 4.5 mm screw underneath the A/V flap.
    • On the top of the camera, remove the 4.0 mm screw on the left-side wrist strap loop.
  3. Nikon Coolpix P90 Eyepiece Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix P90 Eyepiece Replacement: Schritt 3, Bild 2 von 2
    • Lift up the LCD screen to reveal the two screws.
    • Use a Phillips #000 screwdriver to remove the two 3.0 mm screws that hold the arm in place.
  4. Nikon Coolpix P90 Eyepiece Replacement: Schritt 4, Bild 1 von 1
    • Carefully lift up the back cover from the rear side of the camera.
    • Do NOT completely remove the back cover from the camera yet. There is a data transfer ribbon connecting the LCD screen to the motherboard.
  5. Nikon Coolpix P90 Eyepiece Replacement: Schritt 5, Bild 1 von 2 Nikon Coolpix P90 Eyepiece Replacement: Schritt 5, Bild 2 von 2
    • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector. This is the unlocked position.
    • Be careful when releasing the safety latch because it is fragile and may break easily.
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    • It is now safe to completely remove the back cover from the camera.
  6. Nikon Coolpix P90 Eyepiece Replacement: Schritt 6, Bild 1 von 2 Nikon Coolpix P90 Eyepiece Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #000 screwdriver for all of the following steps.
    • On the back side of the camera, remove the seven 4.0 mm screws that connect the metal plate to the motherboard.
    • On the top side or the camera, remove the three 4.0 mm screws that connect the metal hinges to the camera body.
  7. Nikon Coolpix P90 Eyepiece Replacement: Schritt 7, Bild 1 von 1
    • Carefully lift the metal backing from the motherboard.
    • Do NOT completely remove the metal backing yet. There is a data transfer ribbon connecting the metal backing to the motherboard.
  8. Nikon Coolpix P90 Eyepiece Replacement: Schritt 8, Bild 1 von 2 Nikon Coolpix P90 Eyepiece Replacement: Schritt 8, Bild 2 von 2
    • Remove the metal bracket from the camera.
  9. Nikon Coolpix P90 Eyepiece Replacement: Schritt 9, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the 3.0 mm screw that holds the eyepiece in place.
  10. Nikon Coolpix P90 Eyepiece Replacement: Schritt 10, Bild 1 von 1
    • Do NOT completely remove the eyepiece yet. There is a data transfer ribbon connecting the eyepiece to the motherboard.
    • Use a plastic opening tool or spudger, carefully unlock the safety latch that holds the eyepiece data transfer ribbon in place.
    • Slide the ribbon out from its socket.
  11. Nikon Coolpix P90 Eyepiece Replacement: Schritt 11, Bild 1 von 1
    • Gently pull the eyepiece from the camera to remove it.
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 20-14, Maness Winter 2015 Mitglied von Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Excellent Illustrative photographs and instructions
Charles Ikerman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 843
