Einleitung
Use this guide to replace the mirror box and viewfinder.
Note: You'll need JIS screwdrivers for this repair. Regular Phillips screwdrivers have a cross pattern with rounded inner edges and won't fully fit the slots in the JIS screws. JIS screwdrivers instead have a straight cross pattern which makes much better contact with the screw head and is made for the high torque you will need to loosen the screws.
Was du brauchst
Remove the following 5 screws securing the bottom cover to the camera body:
Four 6 mm J000 screws.
One 8 mm J000 screw (under lens mount).
Remove the following screws from the port area:
Two 3.5 mm J000 screws.
One 6 mm J000 screw (right above ports).
Peel the rear rubber piece off with tweezers.
Open the SD card cover by pushing slightly down with your thumb and sliding up.
Remove the following screws that secure the back case:
One 6 mm J000 screw.
One 3 mm J000 screw.
Remove the following screws securing the left motherboard shield:
One 2 mm J000 screw (on the bottom).
One 3.5 mm J000 screw (on the back).
Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
Remove two 6.5 mm J000 screws securing the viewfinder.
Remove the viewfinder cover.
Pull out ribbon cable from circuit asembly near front left of device.
5 weitere Personen haben diese Anleitung absolviert.
