Zum Hauptinhalt wechseln
Nintendo 3DS Charger port Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Nintendo 3DS Charger port Replacement, Charger port: Schritt 1, Bild 1 von 1
    • Take out the 4 screws on the back of the system using a Phillips #00 Screwdriver.
  2. Nintendo 3DS Charger port Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover
  3. Nintendo 3DS Charger port Replacement: Schritt 3, Bild 1 von 1
    • Before proceeding, make sure you have removed the battery.
  4. Nintendo 3DS Charger port Replacement: Schritt 4, Bild 1 von 1
    • You will see small black screws in nine different holes. make sure you use the right screwdriver and remove them. Also remove the one silver screw that holds the game cartridge slot.
  5. Nintendo 3DS Charger port Replacement: Schritt 5, Bild 1 von 1
    • After you have unscrewed all of the screws. Carefully remove the back with a spudger.
  6. Nintendo 3DS Charger port Replacement: Schritt 6, Bild 1 von 1
    • After you pull it open, you will see the motherboard. Locate the charging port. It should look like this.
  7. Nintendo 3DS Charger port Replacement: Schritt 7, Bild 1 von 1
    • Using a soldering iron, desolder the old charging port.
  8. Nintendo 3DS Charger port Replacement: Schritt 8, Bild 1 von 1
    • If you got a charger port for a 3DS, you can skip this step. From another 3DS, desolder the charger port.
  9. Nintendo 3DS Charger port Replacement: Schritt 9, Bild 1 von 1
    • Solder the new charging port to the motherboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Kaylee Morton
275 Reputation
1 Anleitung geschrieben
2 Kommentare
you solder with everything connected to the mobo??
jrsalinas85 - Antwort
Everything but the battery. I actually took mine out of the case before doing anything. But I kept it connected to the screen. I would not do this without a very fine soldering gun.
Timothy Phillips -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 3,312
