Zum Hauptinhalt wechseln
Nintendo 3DS SD Card Replacement / Troubleshooting
Was du brauchst
  1. Nintendo 3DS SD Card Replacement / Troubleshooting, Remove the SD card: Schritt 1, Bild 1 von 2 Nintendo 3DS SD Card Replacement / Troubleshooting, Remove the SD card: Schritt 1, Bild 2 von 2
    • On the left hand side of the system, you should find a small plastic piece saying SD card. Open it via the notch at the top and press in the SD card until it clicks. Then just pull it out.
    • If the card is stuck, use pliers to pull the card out. Do so slowly and with a constant force so that it comes out smoothly.
  2. Nintendo 3DS SD Card Replacement / Troubleshooting, SD card checks: Schritt 2, Bild 1 von 2 Nintendo 3DS SD Card Replacement / Troubleshooting, SD card checks: Schritt 2, Bild 2 von 2
    • Another pretty simple step: check that the card isn't locked. There should be a small switch at the side of the card which, shockingly, says "lock". Make sure the switch is the farthest away that it can be from that word, and you're good to go.
    • If the system tells you that the card is locked when it shouldn't be, use tape to hold down the lock switch securely.
    • While we're doing that, also look for any dirt or dust on the SD card or in its slot. If there is, try cleaning it with a soft cloth, or blowing it out with some compressed air.
  3. Nintendo 3DS SD Card Replacement / Troubleshooting, Find the problem: Schritt 3, Bild 1 von 1
    • Now it time to really look into things. First suspect is the SD card. Slip it into a PC and see if it can detect the SD card.
    • Is it blank? Does it refuse show up? If so, there is probably an issue with the card itself. See if you can find/buy a spare one, and copy over any backup you may have made beforehand.
    • Does the computer read the SD card? It may be time to crack it open and replace the SD card reader.
    • If you're really squeamish about cracking things open before knowing for sure, try another SD card in the 3DS. The card you're using may just be faulty.
Abschluss
By following through the previous instructions, you should now know what the issue is. Either you really had nothing to worry about, you need a new SD card, or you’ll have to replace the 3DS’ SD card module. The first two are easy, and if necessary you can run out to Walmart to pick up an SD card.
In regards to replacing the SD module though, that can be found here: Nintendo 3DS SD Kartenleser austauschen
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Nosh Ware
260 Reputation
1 Anleitung geschrieben
Kid fixers Mitglied von Kid fixers
Community
158 Mitglieder
295 Anleitungen geschrieben
2 Kommentare
if your sd card door its self is jammed try this "technique" A Jammed SD Card Tray
Sqwerks - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 112
Insgesamt: 1,829
