Zum Hauptinhalt wechseln
Nokia 3100b Screen Replacement
Was du brauchst
  1. Nokia 3100b Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure your phone is turned off.
    Frag FixBot
    Kommentar hinzufügen
  2. Nokia 3100b Screen Replacement: Schritt 2, Bild 1 von 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    Frag FixBot
  3. Nokia 3100b Screen Replacement, SIM Card: Schritt 3, Bild 1 von 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    Frag FixBot
  4. Nokia 3100b Screen Replacement: Schritt 4, Bild 1 von 1
    • Retrieve your SIM card.
    Frag FixBot
  5. Nokia 3100b Screen Replacement, Screen: Schritt 5, Bild 1 von 1
    • Separate the front cover from the main body of the phone.
    Frag FixBot
  6. Nokia 3100b Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the six screws along the edges of the phone.
    Frag FixBot
  7. Nokia 3100b Screen Replacement: Schritt 7, Bild 1 von 1
    • Pull the screen assembly from the base of the phone.
    Frag FixBot
  8. Nokia 3100b Screen Replacement: Schritt 8, Bild 1 von 1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
    Frag FixBot
  9. Nokia 3100b Screen Replacement: Schritt 9, Bild 1 von 1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
    Frag FixBot
  10. Nokia 3100b Screen Replacement: Schritt 10, Bild 1 von 1
    • Gently push down on the screen to pop it off of the assembly.
    Frag FixBot
  11. Nokia 3100b Screen Replacement: Schritt 11, Bild 1 von 1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 29-64, Johann Spring 2010 Mitglied von Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 41
Insgesamt: 2,217
