Zum Hauptinhalt wechseln
Nook Color Buttons Replacement
Was du brauchst
  1. Nook Color Buttons Replacement, Back Cover: Schritt 1, Bild 1 von 2 Nook Color Buttons Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. Nook Color Buttons Replacement: Schritt 2, Bild 1 von 2 Nook Color Buttons Replacement: Schritt 2, Bild 2 von 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
    Frag FixBot
  3. Nook Color Buttons Replacement, Front Cover: Schritt 3, Bild 1 von 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
    Frag FixBot
  4. Nook Color Buttons Replacement: Schritt 4, Bild 1 von 2 Nook Color Buttons Replacement: Schritt 4, Bild 2 von 2
    • Pry off the front panel using the plastic opening tool.
    Frag FixBot
  5. Nook Color Buttons Replacement: Schritt 5, Bild 1 von 2 Nook Color Buttons Replacement: Schritt 5, Bild 2 von 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
    Frag FixBot
  6. Nook Color Buttons Replacement, Buttons: Schritt 6, Bild 1 von 3 Nook Color Buttons Replacement, Buttons: Schritt 6, Bild 2 von 3 Nook Color Buttons Replacement, Buttons: Schritt 6, Bild 3 von 3
    • Once you have removed both the back and front panels of the device, you will isolate the panel which contains the buttons. You will remove the volume buttons on the top right first. Use some force upwards and the button will slide free.
    Frag FixBot
  7. Nook Color Buttons Replacement: Schritt 7, Bild 1 von 3 Nook Color Buttons Replacement: Schritt 7, Bild 2 von 3 Nook Color Buttons Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Next, you will remove the power button from the top left of the middle portion of your device. Using tweezers you will carefully lift the button from where it sits and remove it.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 11-5, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 31
Insgesamt: 1,178
