Zum Hauptinhalt wechseln
Nook Simple Touch with GlowLight Charging Port Replacement
Was du brauchst
  1. Nook Simple Touch with GlowLight Charging Port Replacement, Power Button: Schritt 1, Bild 1 von 1
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Charging Port Replacement, Back Cover: Schritt 4, Bild 1 von 1
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Charging Port Replacement, Battery: Schritt 6, Bild 1 von 2 Nook Simple Touch with GlowLight Charging Port Replacement, Battery: Schritt 6, Bild 2 von 2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
  7. Nook Simple Touch with GlowLight Charging Port Replacement, Motherboard: Schritt 7, Bild 1 von 1
    • Remove eleven screws from the motherboard using the T4 screwdriver.
  8. Nook Simple Touch with GlowLight Charging Port Replacement: Schritt 8, Bild 1 von 3 Nook Simple Touch with GlowLight Charging Port Replacement: Schritt 8, Bild 2 von 3 Nook Simple Touch with GlowLight Charging Port Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
  9. Nook Simple Touch with GlowLight Charging Port Replacement, Charging Port: Schritt 9, Bild 1 von 1
    • Flip the motherboard over and locate the charging port.
  10. Nook Simple Touch with GlowLight Charging Port Replacement: Schritt 10, Bild 1 von 1
    • Using a soldering iron, disconnect the charging port from the motherboard.
    • Use the soldering iron to attach the new charging port to the motherboard.
    • Be careful with the soldering iron - it is very hot and can damage your hands or the device.
Abschluss
Sydney Segear
401 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 315
