Einleitung
This guide will show you how to remove the front and rear cameras. The front and rear cameras must be replaced together.
Was du brauchst
Place the plastic opening tool between the front and rear cover and pry up on each corner of the cover.
Remove each camera from the front cover assembly. They are simply held in by tension.
