Zum Hauptinhalt wechseln
Oculus Rift DK1 Control Box Buttons Replacement
Was du brauchst
  1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: Schritt 1, Bild 1 von 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: Schritt 1, Bild 2 von 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: Schritt 1, Bild 3 von 3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
    Frag FixBot
    Kommentar hinzufügen
  2. Oculus Rift DK1 Control Box Buttons Replacement: Schritt 2, Bild 1 von 3 Oculus Rift DK1 Control Box Buttons Replacement: Schritt 2, Bild 2 von 3 Oculus Rift DK1 Control Box Buttons Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
    Frag FixBot
  3. Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: Schritt 3, Bild 1 von 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: Schritt 3, Bild 2 von 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: Schritt 3, Bild 3 von 3
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
    Frag FixBot
  4. Oculus Rift DK1 Control Box Buttons Replacement: Schritt 4, Bild 1 von 3 Oculus Rift DK1 Control Box Buttons Replacement: Schritt 4, Bild 2 von 3 Oculus Rift DK1 Control Box Buttons Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
    Frag FixBot
  5. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Buttons: Schritt 5, Bild 1 von 1
    • You now have the motherboard separated from the control box.
    • Identify the buttons that are not working.
    Frag FixBot
  6. Oculus Rift DK1 Control Box Buttons Replacement, Desoldering Button: Schritt 6, Bild 1 von 1
    • For each button that needs to be replaced, use a soldering iron and soldering braid to desolder the four metal points.
    • Be careful! Soldering iron is hot.
    Frag FixBot
  7. Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: Schritt 7, Bild 1 von 2 Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Now that each button with issues is desoldered, use tweezers to grab each button and detach from the motherboard.
    • If the button does not come off easily, go back to the previous step and ensure each of the four metal points are properly desoldered.
    Frag FixBot
Abschluss
Cal Poly, Team 70-5, Forte Winter 2015 Mitglied von Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 963
