Einleitung
If there are cracks or mars in the video display, the display screen may be broken.
Was du brauchst
Remove front cover plate.
Unplug the USB and HDMI cables from the Oculus Rift DK2.
With the screws removed, gently pull the headband frame apart from the headset.
With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
Remove the six 1/4" Phillips #1 screws as shown. There should be two on each short side, and one on each long side.
Gently lift the plastic screen holder and display screen away from the remaining piece of the faceplate.
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
It's possible to use the Samsung Galaxy Note 4 screen?
