Zum Hauptinhalt wechseln
Optoma HD20 Color Wheel Replacement
Was du brauchst
  1. Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: Schritt 1, Bild 1 von 2 Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: Schritt 1, Bild 2 von 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    Frag FixBot
    Kommentar hinzufügen
  2. Optoma HD20 Color Wheel Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    Frag FixBot
  3. Optoma HD20 Color Wheel Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    Frag FixBot
  4. Optoma HD20 Color Wheel Replacement: Schritt 4, Bild 1 von 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    Frag FixBot
  5. Optoma HD20 Color Wheel Replacement, Color Wheel: Schritt 5, Bild 1 von 1
    • Use the plastic opening tool to remove the wiring.
    Frag FixBot
  6. Optoma HD20 Color Wheel Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
    Frag FixBot
  7. Optoma HD20 Color Wheel Replacement: Schritt 7, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove 1 more 5.5 mm screw.
    Frag FixBot
  8. Optoma HD20 Color Wheel Replacement: Schritt 8, Bild 1 von 1
    • Using a flat head screw driver unscrew the back part to release the color wheel.
    • Do this carefully because these screws do not pull out.
    Frag FixBot
  9. Optoma HD20 Color Wheel Replacement: Schritt 9, Bild 1 von 1
    • Once unscrewed, remove the color wheel, and replace the part.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Trever
1.282 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 21-23, Maness Winter 2015 Mitglied von Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Mitglieder
3 Kommentare zur Anleitung
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
srbaucom - Antwort Teilen
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter - Antwort Teilen
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 55
Insgesamt: 9,875
