Zum Hauptinhalt wechseln
Optoma HD72 Color Wheel Replacement
Was du brauchst
  1. Optoma HD72 Color Wheel Replacement, Upper Case: Schritt 1, Bild 1 von 2 Optoma HD72 Color Wheel Replacement, Upper Case: Schritt 1, Bild 2 von 2
    • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
    Frag FixBot
    Kommentar hinzufügen
  2. Optoma HD72 Color Wheel Replacement: Schritt 2, Bild 1 von 1
    • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
    • Disconnect the two cables that connect the top case to the motherboard.
    • Lift the upper case up and off.
    Frag FixBot
  3. Optoma HD72 Color Wheel Replacement, Motherboard: Schritt 3, Bild 1 von 3 Optoma HD72 Color Wheel Replacement, Motherboard: Schritt 3, Bild 2 von 3 Optoma HD72 Color Wheel Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Disconnect all of the cables that are connected to the motherboard.
    Frag FixBot
  4. Optoma HD72 Color Wheel Replacement: Schritt 4, Bild 1 von 1
    • Remove the four 2 mm Phillips screws that secure the motherboard.
    • Lift the motherboard up and out of the chassis.
    Frag FixBot
  5. Optoma HD72 Color Wheel Replacement, Color Wheel: Schritt 5, Bild 1 von 3 Optoma HD72 Color Wheel Replacement, Color Wheel: Schritt 5, Bild 2 von 3 Optoma HD72 Color Wheel Replacement, Color Wheel: Schritt 5, Bild 3 von 3
    • Remove the three 2 mm Phillips screws that secure the black housing.
    • Lift the black housing off.
    Frag FixBot
  6. Optoma HD72 Color Wheel Replacement: Schritt 6, Bild 1 von 2 Optoma HD72 Color Wheel Replacement: Schritt 6, Bild 2 von 2
    • Remove the single 2 mm Phillips screw that secures the color wheel.
    • Lift the color wheel up and out of its housing.
    Frag FixBot
  7. Optoma HD72 Color Wheel Replacement: Schritt 7, Bild 1 von 3 Optoma HD72 Color Wheel Replacement: Schritt 7, Bild 2 von 3 Optoma HD72 Color Wheel Replacement: Schritt 7, Bild 3 von 3
    • Remove the single 2 mm Phillips screw that secures the circuit board to the side of the color wheel.
    • Use a sharp tool to cut the zip tie that secures the color wheel’s cables.
    • Remove the color wheel.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 35
Insgesamt: 403
