Zum Hauptinhalt wechseln
PDP Rematch Advanced Back Buttons Replacement
Was du brauchst
  1. PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: Schritt 1, Bild 1 von 3 PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: Schritt 1, Bild 2 von 3 PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: Schritt 1, Bild 3 von 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    Frag FixBot
    Kommentar hinzufügen
  2. PDP Rematch Advanced Back Buttons Replacement: Schritt 2, Bild 1 von 3 PDP Rematch Advanced Back Buttons Replacement: Schritt 2, Bild 2 von 3 PDP Rematch Advanced Back Buttons Replacement: Schritt 2, Bild 3 von 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    Frag FixBot
  3. PDP Rematch Advanced Back Buttons Replacement: Schritt 3, Bild 1 von 2 PDP Rematch Advanced Back Buttons Replacement: Schritt 3, Bild 2 von 2
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
    Frag FixBot
  4. PDP Rematch Advanced Back Buttons Replacement, Back Shell: Schritt 4, Bild 1 von 2 PDP Rematch Advanced Back Buttons Replacement, Back Shell: Schritt 4, Bild 2 von 2
    • Grab the motor and pull away from the back shell. Repeat for both motors.
    Frag FixBot
  5. PDP Rematch Advanced Back Buttons Replacement: Schritt 5, Bild 1 von 2 PDP Rematch Advanced Back Buttons Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
    Frag FixBot
  6. PDP Rematch Advanced Back Buttons Replacement: Schritt 6, Bild 1 von 3 PDP Rematch Advanced Back Buttons Replacement: Schritt 6, Bild 2 von 3 PDP Rematch Advanced Back Buttons Replacement: Schritt 6, Bild 3 von 3
    • Remove the motherboard from the back shell using moderate force.
    Frag FixBot
  7. PDP Rematch Advanced Back Buttons Replacement, Back Buttons: Schritt 7, Bild 1 von 2 PDP Rematch Advanced Back Buttons Replacement, Back Buttons: Schritt 7, Bild 2 von 2
    • Use a Phillips #00 to remove the two 5mm screws from the back buttons.
    Frag FixBot
  8. PDP Rematch Advanced Back Buttons Replacement: Schritt 8, Bild 1 von 3 PDP Rematch Advanced Back Buttons Replacement: Schritt 8, Bild 2 von 3 PDP Rematch Advanced Back Buttons Replacement: Schritt 8, Bild 3 von 3
    • Lift the back button, and then pull it out through the back shell. Do this for both back buttons.
    Frag FixBot
Abschluss
Utah Tech University, Team 1-1, McMurrin Spring 2024 Mitglied von Utah Tech University, Team 1-1, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G1
2 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 40
Insgesamt: 679
