Zum Hauptinhalt wechseln
PDP Rematch Advanced Back Shell Replacement
Was du brauchst
    1. PDP Rematch Advanced Back Shell Replacement, Joystick Cover: Schritt 1, Bild 1 von 3 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: Schritt 1, Bild 2 von 3 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: Schritt 1, Bild 3 von 3
      • Orient the controller so the back side is facing you.
      • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
      Frag FixBot
      Kommentar hinzufügen
    2. PDP Rematch Advanced Back Shell Replacement: Schritt 2, Bild 1 von 3 PDP Rematch Advanced Back Shell Replacement: Schritt 2, Bild 2 von 3 PDP Rematch Advanced Back Shell Replacement: Schritt 2, Bild 3 von 3
      • Pull apart the controller's front and back shells with moderate force.
      • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
      Frag FixBot
    3. PDP Rematch Advanced Back Shell Replacement: Schritt 3, Bild 1 von 2 PDP Rematch Advanced Back Shell Replacement: Schritt 3, Bild 2 von 2
      • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
      Frag FixBot
    1. PDP Rematch Advanced Back Shell Replacement, Back Shell: Schritt 4, Bild 1 von 2 PDP Rematch Advanced Back Shell Replacement, Back Shell: Schritt 4, Bild 2 von 2
      • Grab the motor and pull away from the back shell. Repeat for both motors.
      Frag FixBot
    2. PDP Rematch Advanced Back Shell Replacement: Schritt 5, Bild 1 von 2 PDP Rematch Advanced Back Shell Replacement: Schritt 5, Bild 2 von 2
      • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
      Frag FixBot
    3. PDP Rematch Advanced Back Shell Replacement: Schritt 6, Bild 1 von 3 PDP Rematch Advanced Back Shell Replacement: Schritt 6, Bild 2 von 3 PDP Rematch Advanced Back Shell Replacement: Schritt 6, Bild 3 von 3
      • Remove the motherboard from the back shell using moderate force.
      Frag FixBot
Abschluss
Utah Tech University, Team 1-1, McMurrin Spring 2024 Mitglied von Utah Tech University, Team 1-1, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G1
2 Mitglieder
66 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 33
Insgesamt: 544
