Zum Hauptinhalt wechseln
Pantech Matrix Keypad Replacement
Was du brauchst
  1. Pantech Matrix Keypad Replacement, Phone Orientation: Schritt 1, Bild 1 von 1
    • Place phone with screen side facing toward you.
    Frag FixBot
    Kommentar hinzufügen
  2. Pantech Matrix Keypad Replacement, Phone Orientation: Schritt 2, Bild 1 von 1
    • Flip phone over so screen side is now facing down.
    Frag FixBot
  3. Pantech Matrix Keypad Replacement, Remove Back Cover: Schritt 3, Bild 1 von 2 Pantech Matrix Keypad Replacement, Remove Back Cover: Schritt 3, Bild 2 von 2
    • Gently slide the backside phone cover off exposing the battery underneath.
    Frag FixBot
  4. Pantech Matrix Keypad Replacement, Lift Battery: Schritt 4, Bild 1 von 1
    • Carefully lift the battery up from where the spudger is pointed.
    Frag FixBot
  5. Pantech Matrix Keypad Replacement, Remove Battery: Schritt 5, Bild 1 von 1
    • Remove the battery from its dock.
    Frag FixBot
  6. Pantech Matrix Keypad Replacement, Slide SIM Card Out: Schritt 6, Bild 1 von 3 Pantech Matrix Keypad Replacement, Slide SIM Card Out: Schritt 6, Bild 2 von 3 Pantech Matrix Keypad Replacement, Slide SIM Card Out: Schritt 6, Bild 3 von 3
    • Slide the SIM Card out of its dock.
    Frag FixBot
  7. Pantech Matrix Keypad Replacement, Remove Phone Screws: Schritt 7, Bild 1 von 2 Pantech Matrix Keypad Replacement, Remove Phone Screws: Schritt 7, Bild 2 von 2
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
    Frag FixBot
  8. Pantech Matrix Keypad Replacement, Remove Phone Casing: Schritt 8, Bild 1 von 2 Pantech Matrix Keypad Replacement, Remove Phone Casing: Schritt 8, Bild 2 von 2
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside.
    Frag FixBot
  9. Pantech Matrix Keypad Replacement, Remove Camera Screws: Schritt 9, Bild 1 von 2 Pantech Matrix Keypad Replacement, Remove Camera Screws: Schritt 9, Bild 2 von 2
    • Place phone with exposed motherboard facing you.
    • Use a Phillips screwdriver to remove the five 2mm Phillips #000 screws holding the camera in place.
    Frag FixBot
  10. Pantech Matrix Keypad Replacement, Expose Keypad: Schritt 10, Bild 1 von 1
    • Carefully lift up the motherboard to expose the back of the keypad.
    Frag FixBot
  11. Pantech Matrix Keypad Replacement, Remove Keypad: Schritt 11, Bild 1 von 2 Pantech Matrix Keypad Replacement, Remove Keypad: Schritt 11, Bild 2 von 2
    • Use spudger to gently pry the keypad away from the rest of the phone.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Zeel Patel
1.096 Reputation
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 25
Insgesamt: 471
