Zum Hauptinhalt wechseln
Pentax PZ-10 Back Cover Locking Switch Spring Replacement
Was du brauchst
    1. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Bottom Cover: Schritt 1, Bild 1 von 1
      • With the lens face up and the bottom panel of the camera facing you, remove the two 7mm screws on the left using the J0 screwdriver.
      • Remove the six 4.3mm screws in the middle and right of the panel using the J0 screwdriver.
      • Pull off the bottom casing to remove.
      Frag FixBot
      Kommentar hinzufügen
    2. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing Bottom Casing: Schritt 2, Bild 1 von 1
      • With the screws removed, the bottom casing should come off very easily by pulling on the casing.
      Frag FixBot
    3. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Back Cover: Schritt 3, Bild 1 von 1
      • Place the camera on its side so the lens is facing left.
      • Press down on the locking switch on the side panel facing you.
      Frag FixBot
    4. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: Schritt 4, Bild 1 von 1
      • With the door unlocked, rotate the device to access the bottom.
      Frag FixBot
    5. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: Schritt 5, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • Using a pair of tweezers, gently remove the metal tab securing the back door axle.
      • The door will come loose at this point, watch for any loose parts that may also come out.
      Frag FixBot
    6. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Side Panel: Schritt 6, Bild 1 von 1
      • Once the back cover is fully removed, remove the two 4.35mm screws attaching the cover of the unlocking switch, and remove the plate.
      Frag FixBot
    7. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Spring: Schritt 7, Bild 1 von 1
      • Locate the spring at the upper left corner of the face, and pull the rings of the spring off of the pins to remove it using plastic opening tools.
      • You are now ready to replace the spring.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 742
