Zum Hauptinhalt wechseln
Pentax Super Program Mirror Box Mechanism Service
Was du brauchst
    1. Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: Schritt 1, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: Schritt 1, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: Schritt 1, Bild 3 von 3
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      Frag FixBot
      Kommentar hinzufügen
    2. Pentax Super Program Mirror Box Mechanism Service, Remove mode dial: Schritt 2, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Remove mode dial: Schritt 2, Bild 2 von 2
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      Frag FixBot
    3. Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: Schritt 3, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: Schritt 3, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: Schritt 3, Bild 3 von 3
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      Frag FixBot
    4. Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: Schritt 4, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: Schritt 4, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: Schritt 4, Bild 3 von 3
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      Frag FixBot
    5. Pentax Super Program Mirror Box Mechanism Service, Remove top cover: Schritt 5, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove top cover: Schritt 5, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove top cover: Schritt 5, Bild 3 von 3
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      Frag FixBot
    1. Pentax Super Program Mirror Box Mechanism Service, Remove bottom cover: Schritt 6, Bild 1 von 1
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      Frag FixBot
    1. Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: Schritt 7, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: Schritt 7, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: Schritt 7, Bild 3 von 3
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      Frag FixBot
    2. Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB with adjustment pots: Schritt 8, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB with adjustment pots: Schritt 8, Bild 2 von 2
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      Frag FixBot
    3. Pentax Super Program Mirror Box Mechanism Service, Unsolder motor drive connections: Schritt 9, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Unsolder motor drive connections: Schritt 9, Bild 2 von 2
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      Frag FixBot
    4. Pentax Super Program Mirror Box Mechanism Service, Remove tripod mount: Schritt 10, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Remove tripod mount: Schritt 10, Bild 2 von 2
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      Frag FixBot
    5. Pentax Super Program Mirror Box Mechanism Service, Detach ISO resistor assembly: Schritt 11, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Detach ISO resistor assembly: Schritt 11, Bild 2 von 2
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      Frag FixBot
    6. Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: Schritt 12, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: Schritt 12, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: Schritt 12, Bild 3 von 3
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      Frag FixBot
    7. Pentax Super Program Mirror Box Mechanism Service, Unsolder flash sync wires: Schritt 13, Bild 1 von 1
      • Unsolder two gray wires.
      Frag FixBot
    8. Pentax Super Program Mirror Box Mechanism Service, Unsolder shutter wires: Schritt 14, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Unsolder shutter wires: Schritt 14, Bild 2 von 2
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      Frag FixBot
    9. Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: Schritt 15, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: Schritt 15, Bild 2 von 2
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      Frag FixBot
    10. Pentax Super Program Mirror Box Mechanism Service, Unscrew front board: Schritt 16, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Unscrew front board: Schritt 16, Bild 2 von 2
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      Frag FixBot
    11. Pentax Super Program Mirror Box Mechanism Service, Remove mirror box and front board: Schritt 17, Bild 1 von 1
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      Frag FixBot
    12. Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Front Block: Schritt 18, Bild 1 von 1
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      Frag FixBot
    1. Pentax Super Program Mirror Box Mechanism Service, Unsolder Main PCB: Schritt 19, Bild 1 von 1
      • Unsolder one orange and one blue wire for the mirror release solenoid.
      • Unsolder one pink wire for the LCD backlight.
      • Unsolder two purple wires for the TL switch.
      • Unsolder one green wire for the MD switch.
      Frag FixBot
    2. Pentax Super Program Mirror Box Mechanism Service, Unsolder lens mount connections (early production): Schritt 20, Bild 1 von 1
      • Unsolder six wires for the lens mount pin connections.
      • These are only present on the early production models. Later production models moved these connection points to the flex connector.
      Frag FixBot
    3. Pentax Super Program Mirror Box Mechanism Service, Unsolder aperture resistor: Schritt 21, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Unsolder aperture resistor: Schritt 21, Bild 2 von 2
      • Unsolder two yellow wires for the aperture resistor.
      Frag FixBot
    4. Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: Schritt 22, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: Schritt 22, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: Schritt 22, Bild 3 von 3
      • Unsolder the red and black wires for the metering cells in the eye piece.
      • Unsolder pink and green wires for the flash sync connections.
      Frag FixBot
    5. Pentax Super Program Mirror Box Mechanism Service, Unsolder front board connections (early production): Schritt 23, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Unsolder front board connections (early production): Schritt 23, Bild 2 von 2
      • Unsolder blue and black wires for self-timer LED.
      • Unsolder orange wire for beeper.
      • Unsolder gray and pink wires for aperture solenoid.
      • Unsolder light blue and yellow wires for aperture optical encoder.
      • Unsolder purple wire for self-timer contact.
      • Remove one screw.
      Frag FixBot
    6. Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB connection (late production): Schritt 24, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB connection (late production): Schritt 24, Bild 2 von 2
      • Remove two M1.4 x 2 mm screws.
      • Use a spudger to gently pry off the connector plate.
      • Remove the silicone insulating pad.
      Frag FixBot
    7. Pentax Super Program Mirror Box Mechanism Service, Detach viewfinder LCD: Schritt 25, Bild 1 von 1
      • Remove two M1.4 x 1.6 mm screws.
      • Look for shim washers when removing and note their position.
      Frag FixBot
    8. Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: Schritt 26, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: Schritt 26, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: Schritt 26, Bild 3 von 3
      • Loosen one M1.7 x 4.5 mm screw but leave it in place.
      • Remove two M1.7 x 1.6 mm screws.
      • Remove the mirror governor.
      • Remove one plastic bushing.
      Frag FixBot
    9. Pentax Super Program Mirror Box Mechanism Service, Remove main PCB: Schritt 27, Bild 1 von 1
      • Gently lift away the PCB from the mirror box.
      • The TTL flash metering cell needs to be unseated from the side of the mirror box to free the PCB for removal.
      Frag FixBot
    1. Pentax Super Program Mirror Box Mechanism Service, Detach front flex PCB: Schritt 28, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Detach front flex PCB: Schritt 28, Bild 2 von 2
      • Lift flex PCB off of mounting posts.
      • Remove silicone insulator pad.
      Frag FixBot
    2. Pentax Super Program Mirror Box Mechanism Service, Remove beeper: Schritt 29, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Remove beeper: Schritt 29, Bild 2 von 2
      • Remove one screw and retainer plate.
      • Remove beeper.
      Frag FixBot
    3. Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: Schritt 30, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: Schritt 30, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: Schritt 30, Bild 3 von 3
      • Remove two M2 x 3 mm screws.
      • Remove one M1.7 x 3 mm screw.
      • Charge and release the mirror so it is in the taking position (up against the focusing screen).
      Frag FixBot
    4. Pentax Super Program Mirror Box Mechanism Service, Remove mirror box: Schritt 31, Bild 1 von 1
      • Lift mirror box away from front lens board.
      Frag FixBot
    5. Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Mirror Box: Schritt 32, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Mirror Box: Schritt 32, Bild 2 von 2
      • Check the following coupling points between the front lens board and the mirror box.
      • Aperture control.
      • Self-timer lever is above the mirror release latch.
      • Depth of field preview lever.
      Frag FixBot
      • Insert wisdom here.
      Frag FixBot
    1. Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: Schritt 34, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: Schritt 34, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: Schritt 34, Bild 3 von 3
      • Remove one M1.3 x 2.1 mm shoulder screw.
      • Remove one M1.3 x 2.4 mm screw.
      • Remove coil spring.
      • Note the rubber bumper on the pivot post. This should be removed and cleaned before reassembly.
      Frag FixBot
    2. Pentax Super Program Mirror Box Mechanism Service, Remove shutter release lever: Schritt 35, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Remove shutter release lever: Schritt 35, Bild 2 von 2
      • Remove one M1.5 x 3.5 mm screw.
      • Remove the bias spring.
      • Remove the brass bushing.
      Frag FixBot
    3. Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: Schritt 36, Bild 1 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: Schritt 36, Bild 2 von 3 Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: Schritt 36, Bild 3 von 3
      • Unhook and remove the coil spring. It may be tacked in place with lacquer.
      • Remove one M1.3 x 4.5 mm screw.
      • Remove the depth of field preview lever.
      • Remove the bushing.
      Frag FixBot
    4. Pentax Super Program Mirror Box Mechanism Service, Remove auto-aperture control lever: Schritt 37, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Remove auto-aperture control lever: Schritt 37, Bild 2 von 2
      • Use a spanner wrench or u-bit to remove two nuts.
      • Lift off auto-aperture control lever.
      Frag FixBot
    5. Pentax Super Program Mirror Box Mechanism Service, Remove mirror flip-up lever: Schritt 38, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Remove mirror flip-up lever: Schritt 38, Bild 2 von 2
      • Lift off mirror flip-up lever.
      • Remove shim washer.
      • Remove plastic bushing.
      Frag FixBot
    6. Pentax Super Program Mirror Box Mechanism Service, Remove aperture stop-down lever: Schritt 39, Bild 1 von 2 Pentax Super Program Mirror Box Mechanism Service, Remove aperture stop-down lever: Schritt 39, Bild 2 von 2
      • Remove aperture stop-down lever.
      • Installation Notes: Ensure the lever foot is placed properly between the mirror flip-up spring and the mirror return lever during reassembly.
      Frag FixBot
    7. Pentax Super Program Mirror Box Mechanism Service, Clean mirror box components: Schritt 40, Bild 1 von 1
      • Remove two old rubber bumpers.
      • Clean all pivots with isopropyl alcohol.
      • Clean all removed components with isopropyl alcohol.
      Frag FixBot
    8. Pentax Super Program Mirror Box Mechanism Service, Reassembly Notes: Schritt 41, Bild 1 von 1
      • The mirror mechanism does not need lubrication to operate properly. Most moving interfaces run dry.
      • High friction latching points can be lubricated with a heavy moly grease to reduce wear.
      • Replacement rubber dampers are optional. Silicone tubing cut to length is good source.
      Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 49
Insgesamt: 548
