Einleitung
This is the Perfect Cooker RC301M. In this guide, we will be disassembling this rice cooker to gain a better idea of how this device works and for optimal cleaning.
Was du brauchst
Angehängtes Dokument
Remove the power cord and find a clean flat surface to work at.
Remove the lid by unhinging the side tabs.
Remove the inner pot and any other contents.
Flip the device over and look for the two screws recessed underneath the device.
This part of the device raises and lowers the burner to change from the cook to warm function.
Disconnect the two metal arms.
Take the small chain nose pliers and bend each side of the “T-shaped” tab inwards.
Separate the two parts of the devices.
The "U-shape" cut out can now be clearly seen.
The T-tab remains in the "U-shape" after slipping through the slot.
