Zum Hauptinhalt wechseln
Plantronics CS50 Headset System Reset
    1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: Schritt 1, Bild 1 von 2 Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: Schritt 1, Bild 2 von 2
      • Press and hold both the call control button and the listening volume/mute button for five seconds.
      • When the talk indicator light blinks, release both buttons.
      Frag FixBot
      Kommentar hinzufügen
    2. Plantronics CS50 Headset System Reset: Schritt 2, Bild 1 von 1
      • Press the call control button again.
      Frag FixBot
    3. Plantronics CS50 Headset System Reset: Schritt 3, Bild 1 von 2 Plantronics CS50 Headset System Reset: Schritt 3, Bild 2 von 2
      • Unplug the base unit's power source for ten seconds.
      • Plug the power source back in.
      Frag FixBot
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
Joe
117 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 17-29, Amido Spring 2012 Mitglied von Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Mitglieder
83 Anleitungen geschrieben
4 Kommentare zur Anleitung
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - Antwort Teilen
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - Antwort Teilen
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - Antwort Teilen
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 88
Insgesamt: 23,546
