Einleitung
This guide will show users how to replace the battery in the Polar V800. If the battery appears at the end of its life cycle or has become swollen, then the battery may need to be replaced to keep your Polar V800 sport watch operating as it should.
Was du brauchst
Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
Remove the nine, 4.0 millimeter-long screws with a T5 head-type torque screwdriver.
Once all of the screws have been removed, lift the motherboard to expose the battery beneath motherboard.
Gently pull the wires from their solder joints to disconnect them from the body of the watch.
To remove the battery, desolder the black and red wires connecting the battery to the motherboard and remove the battery. See this guide on Wie man Lötverbindungen herstellt und entlötet for additional help.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
54 Kommentare
@jarodlyles Where can I buy those 7.4 mm long screws? I tried to open my V800 and I think I might have ruined the groves on the screw head. Now, the screw driver just rotates and does not screw in. I am thinking of buying new screws to replace the old ones. Please let me know.
I found so many 3.7 V 350 mAH LiPo batteries with a bit different dimensions. I wan’t to buy the right, before try to change it.
Can you please specify the dimensions of the battery? Or, if possible, a direct link to order one (eBay, Amazon, some shop witch delivery to germany)?
Thanks
Same problem here: where should I buy the replacement battery? Nothing, really nothing found online… :(
